Interest Check --Carver Amazings--Atlanta area
george daniel
I have an opportunity to pickup some Plats,,so,, these are the ones that came from the woodshed @ Ted's. I'll be asking only what I paid,,which was 895.00 IIRC. If interested please pm me. These will be for pickup only.These are the originals I believe,, with the 2 30 inch ribbions. Thanks for looking. George
EDIT: These need to stay in the family if anyway possible.
They are for sale now,, I'm picking up the Platinums on Sat,so I'll leave these here until then.
Thanks for looking.
Price recuced to 800.00
Thanks for looking.
Post edited by george daniel on
I sold these to Ted, yes, they are the Originals w/ 2 30" ribbons.
This is a steal. If economy would have been more gentle to me I would be all over them.
engtazengtaz
"Boutique brands"....."full range too expensive".....pffft!!!
Grab these someone and don't look back.......great deal,great speaks,you'd be hard pressed to find more speaker for the money.HT SYSTEM-
lsi 9's -
I'm currently running Polk SDA SRS 2's. Can anyone tell me how the Carver's compare with these for detail and sound stage. I'm driving my Polks with a Carver amp rated at 675watts per channel and a Carver preamp, using an Oppo 980h for my source. Would this be an upgrade or more of a lateral move? Thanks.
they will be more open and airy, which is good if done right (basically they will disapear in the room a little better than the SDA's) these will be MUCH mroe dependent on placement than your SDA's though. sounds like you got more than enough power (what carver amp is that? Carver Pro?)
those Carvers are 4 ohm I believe, so if your running amps bridged, you would reconsider that on these. this is a speaker every full blooded audio nut has to try to truly be an audio nut. cant be described is words what they can do if set up right.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Thanks for the response ohskigod. I am running a Carver A-760x. It runs 675 per channel in 4 ohm.
I'd say you bring enough amp to the table.
The Amazings do not through the sounstage width that the SDA's do. The Carvers are more detailed, soundstage depth, good one I'd say that's a push. Overall, I'd give the nod to the Amazings being better all around IF (and these are big if's) you have enough amp to drive them and some room for them to breathe.
DAMN good price.
They are now For Sale. Thanks
Yep only 800.00JC approves....he told me so. (F-1 nut) -
I can't believe that I'm bumping these. :rolleyes:JC approves....he told me so. (F-1 nut)
the bass response on these is well Amazing, four 12" woofers per speaker, they go subsonic, add that to the space and detail the ribbons deliver and you end up with a speaker that might be your last. The placement of instruments across the stage is awesome as well as the depth, for 895.00 its a true no brainer.
RT1 -
Those are sweet George. Very very nice condition.
engtaz
Royengtaz
Don't the ribbons or the panels need to be serviced periodically?
How do these compare to the Maggies?
Unless its Bose I am not going to knock anybody's speaker.
These Carvers are speakers you should definetly own, they are outstanding and require very little maintenance, you want to keep them out of a humid environment and supply them with nice clean current. I owned this pair and before me Troy, they were soncially perfect, at some point folks redo the surrounds on the woofers but this set was not lacking in the bass department.
You can spend five to ten times what these cost and not do as well, they are really that good.
RT1 -
But I thought these are flat panel speakers. Do they user woofers? Are the surrounds foam or rubber?
And pardon me for asking, if they are so good, why did you part with them? -
pm sent to buy
Ted,, aquired the Platinum edition,, George is aquiring the Platinum Edition on Saturday,,they have a 60 inch ribbon and have a lesser impedence dip than the originals(2 thirty inch ribbons). Hope this helps.
I've only had a chance to hear the ALS, properly setup, on fredv's tubes. These are truly astounding for clarity, depth and bass. When I have the room, I'll definitely try a pair locally.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Still for sale,,and yes ,I can hold them for 3-6 months if necessary. Thanks.JC approves....he told me so. (F-1 nut)
If I had a way to get them to Canada I'd be on them like a fat kid on a smartie.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
mightymouse wrote: »Don't the ribbons or the panels need to be serviced periodically?
No. Most are over 25 years old and work flawlessly. They are sensitive to high humidity, but that's not a problem in most houses and you just need to reduce the humidity to solve that problem. -
They are flat panels, but not electrostatic. Each speaker has four 12" woofers w/ foam surrounds. Replacement woofers that match the original specs are still available for $35 ea. plus shipping. You can also still get the ribbons re-built with original kaptons. -
Damn good deal...
They're okay. Nothing to write home about.
WTF someone buy these and touch yourself while listening to how good they are2 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
Will have to pass, can't find a sensible way to transport at the moment.
Good Luck on the sale, they are some beaut's.
DaveOnce again we meet at last. -
I'm all set for man-sized speakers right now, but I'm curious as to how sensitive these are to room placement. Best way to situate them? Always wondered that with the unique design.
Extremely sensitive. They must have clean power and room to breathe.
I had an identical pair for about 3 years and they are "Amazing". They're not as power hungry as most believe. I ran them on a Dynaco ST70 and it had no problems driving them clean and hard. I did however notice my Krells at 100wpc didn't do quite as well.
Nice speakers and someone should grab them up. Great price btw.
If you remove the felt off the rear of the ribbons it really opens up the room to nice filling highs. Very smooth.
HB
