if you could choose sub, which one would u pick?
jammer4444
Trying to decide on a sub. From reading/educating myself on this forum I have narrowed the field to 4.
Budget is at $600.
Room is 16.5'W x 25'D x 7.5'H. No windows.
Will be mainly used for movies, ps3 gaming and then music
Choices:
Outlaw LFM-1 Plus - 649
SVS P12-NSD - $599
HSU VTF-2 MK 3 - $499
Polk DSW 600 - $599
Appreciate your listening expertise, thx.
Budget is at $600.
Choices:
SVS P12-NSD - $599
Polk DSW 600 - $599
Post edited by jammer4444 on
Wow. that would be tough. they are all worthy and capable subs. I like the Polk DSW Pro 600, not that I have it.. but I like that it comes with a remote so you can adjust it from your easy chair. and not even have to put down your cocktail.
great idea with the remote.
as it is now. i have to get my butt out of the chair and adjust it manually. it's so last century.
PolkFest 2012, who's going>?
Once you get it calibrated, you don't need to adjust your sub levels
. They are all nice, but the PB12 has been improved. In some ways, it's better than the Plus per Illka's testing. Among those subs that would be my choice. If you can handle a wait, then I'd be considering the Epik Knight or Valor vs. the MFW 15 though.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
funny.....just when i thought i had it narrowed down, another good suggestion appears.....thx. i am on the site as we speak.
I'd choose any Epik sub or Onix MFW-15 over all of those listed.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I 2nd those subs. Very nice subs at a great prices.
engtazengtaz
I like my HSU and would recommend it. Can't go wrong with any of these.
glad i asked, knowledge is power. Now checking out AV123 MFW-15, thx fellas....
The only drawback for either is the wait. Epik's supply chain is down until mid April and I don't know what kind of backlog he has. AV123 is quoting July for any new MFW15 orders. Must be nice to be in demand.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
works for me. just finished building walls/built in cabinets. just starting sound proof and wiring. could be good timing for june/july by the time i git er done. I guess i have a short list now: MFW15 and epik and these look like a coin toss. thx again, great info.
Now I dunno about not adjusting your sub , with my music I play with the sub all the time some audio is recorded differently and needs turned up or down especially when changing from older rock to newer rock bass levels are simply recorded better or my amplified in the newer music it would seem......:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
I'd rather adjust off the pre, so that I can tell where my calibration was last set...which can be done with the remoteDeadof_knight wrote: »Now I dunno about not adjusting your sub , with my music I play with the sub all the time some audio is recorded differently and needs turned up or down especially when changing from older rock to newer rock bass levels are simply recorded better or my amplified in the newer music it would seem......
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Jammer -- for your room size, you'll need to get the biggest, baddest sub you can afford. That's why I recommend a 15" driver that the Epik and Onix subs have. I use a 15" VMPS sub in a 13' x 20' x 8' room and I could still use more bass for HT.
I'd go with the SVS.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Never underestimate the value of a remote for the sub! My eyes have been opened!DKG999
