Honestly please before I buy!
DannyD
DannyD Posts: 133
edited March 2008 in Electronics
I've been thinking about buying a power conditioner for my HT setup. Particularly the Monster 3600. I can get a used one for around $200.00. Do they do anything to help the quality of the sound or are they mainly for surge protection? Is it a noticable difference or are they more for piece of mind that your eqiupment won't get fried?:confused:
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
    F1nut Posts: 52,298
    edited March 2008
    Unless a unit can regenerate power, it's mostly for surge protection. Although, some can help with line noise.
  • dkg999
    dkg999 Posts: 5,647
    edited March 2008
    And if it's used, make sure it hasn't already taken a good hit from a surge. Not all of them are made to take multiple hits.
    DKG999
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2008
    When I lived in my old towhnouse with my former modest HT, I picked up a Monster 2500 and I noticed a good difference in the sound. Even my roommate (the devil) noticed and she is oblivious to anything audio. It sounded cleaner, clearer and more dynamic.
    When I added it to a dedicated line at my new (old) house, I could not tell a difference really.
    So...I guess it depends. If you have a normal line I would say go for it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    treitz3 Posts: 20,276
    edited March 2008
    All of the above are true.
  • polkseller
    polkseller Posts: 184
    edited March 2008
    watch out with cheap prices, refurbished comes with only 90 days warranty instead of 5 years..
    Yes it does make a diff on sound quality and HD picture stability.
  • hockeyboy
    hockeyboy Posts: 1,428
    edited March 2008
    It helps...you sleep at night for sure.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • toddco
    toddco Posts: 147
    edited March 2008
    My 5100 helped alot on older DVDs from the 80s cleaned up alot of the grain y ness.:)
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    PHILLIPS 42" PLAS. 1080i
    Monster 5100 SS
  • zingo
    zingo Posts: 11,258
    edited March 2008
    Plus, any unit like that is just way cooler than a power-strip anyway.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited March 2008
    I bumped up to a HTS 5100 SS for the pretty blue lights. I didn't notice a difference, but it does give piece of mind, organization, and is a nice addition looks-wise in most cases.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited March 2008
    I have both Panamax and Monster power centers, I bought them mostly to switch all my components on and off with a single 12v trigger.
    I have not noticed any difference in picture or sound, although there was never any noise in the system before installing them, so why would I? I would imagine that it depends on the power you are recieving. Are you having power related issues?
