Denon AVR-2805 and Zone 2 question....
shawn474
shawn474 Posts: 3,052
edited March 2008 in Electronics
I now have a Denon AVR-2805 (thanks to Mark) and have an audiosource amp one that I used for my zone 2 with the sony. I have it set up the same way as with the Sony (RCA's from amp to receiver and speakers hooked up to the amp). I now get no sound out of the 2nd room speakers, however. I'm not sure if I overlooked something simple or if this AVR takes a lot more set-up for something like that. Does anyone familiar with this particular AVR please chime in with any thoughts on what may be giving me the problem? Thanks in advance.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • mantis
    mantis Posts: 17,333
    edited March 2008
    You have to have all analog connections between the receiver and the sources. You also have to turn the zone 2 volume up as it comes from the factory all the way down. You can change it from fixed to vari depending on if you have a volume control for your zone 2.
    Dan
  • shawn474
    edited March 2008
    mantis, thanks for the input. I have an analog connection from the cd player to the AVR. I turned on Zone 2 with the remote and turned the volume up - still no sound. I'll have to check when I get home about the fixed or variable. The amp has a seperate volume control so which one should I use? Do you know how to switch between the two options? Sorry for the ignorance, but the manual definitely leaves something to be desired!
    Thanks,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    billbillw Posts: 7,504
    edited March 2008
    shawn474 wrote: »
    Thanks,
    Shawn
    If your Zone 2 amp has a volume control, then use fixed output from the AVR. Sometimes you have to select the source for zone 2 through a separate step. These things never work quite as easy as you'd expect.
  • shawn474
    edited March 2008
    mantis and bill,
    Appreciate the help. I got home and had to set the input as analog on the on screen display for Zone 2 and everything works great. Thanks again.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    I'm glad I could help....oh wait...I didn't do shite.
  • shawn474
    edited March 2008
    Mark,
    Me and my OCD got the best of me............I am sure you can be of help when the next shipment of gear comes in!!!!:D
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
