FS: Sony STR-DA5ES AVR - Near Mint......
shawn474
shawn474 Posts: 3,052
Up for sale is a near mint Sony STR-DA5ES Audio Video Receiver. I am the second owner (first owner was Brent McGhee). I bought it from him on the forum 2 years ago for $400.00 and it has had no problems at all. There are no cosmetic blemishes and it functions flawlessly. See for original thread: http://www.polkaudio.com/forums/showthread.php?t=37379
Some of the features include on-screen display, multi room capability, DTS - ES, Dolby Digital, Dolby Pro-Logic decoding, multiple DSP sound fields among NUMEROUS other features. I am upgrading and have no need for this anymore - Just time to try something new. I know there are not a lot of Sony ES fans here, but this thing is a beast and has A LOT to offer.
This includes the receiver, both remote controls, the power cord and manual (photocopy). It will not include the box. I would prefer to keep this as a local sale as it is heavy and will cost quite a bit to ship properly.
Asking $250.00. If no interest, I will put on e-bay in the next few days or so. Pictures will follow later today if needed but it looks exactly the same as the original thread. EDIT: I have no clue how to add photos, so interested people can PM or e-mail me and I will get them to you. They are ready to be viewed.
Key Features
Type Receiver
Number of Channels 6.1 Channels
Stereo Mode Power 110 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.05%
Surround Mode Power 110 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.05%
Surround Sound Dolby Digital® • DTS ES® • Dolby Pro Logic II
DSP
DSP Modes Arena • Church • Disco • Game • Hall • Jazz • Live • Opera House • Stadium
Inputs / Outputs
Rear Input Connectors RCA (2 Audio Channels) x 8 • Digital Coaxial x 2 • Digital Optical x 4 • Composite (Video) x 4 • S-Video x 4 • Component x 2
Rear Output Connectors RCA (2 Audio Channels) x 5 • Digital Optical x 1 • Composite (Video) x 4 • S-Video x 3 • Component x 1
Front A/V Connections Composite x 1 • Couple RCA Jack x 1 • Headphones x 1 • S-Video x 1
PC Interface RS-232
Surround Analog Inputs 5.1 Channels x 1 • 7.1 Channels x 1
Component Video Bandwidth 50 MHz
Convenience
Number of Zones 3
Tone Controls Bass & Treble
On Screen Display With OSD
Remote Control
Remote Control Type Learning
Design Keypad with Display
Dimensions
Width 16.94 in.
Depth 18.88 in.
Height 6.88 in.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • capitan100
    capitan100 Posts: 172
    edited March 2008
    Wow...great price. I'd be all over this if I hadn't just bought my DA7ES.
    Good luck.
    Sony DA7ES 7.1 A/V Receiver
    Sony DVP-NC80V - SACD/DVD player
    CS400 - Center channel
    RT2000i - Fronts
    RT1000i - Surrounds
    a/d/s MS3/u - subwoofer
    Hitachi 62 inch HD TV
    2 Channel Room
    Niles HDL-4 Speaker Selector
    Niles HDL-6 Speaker Selector
    Sony V555ES receiver
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
    Wharfedale Valdus 100SE
    Polk PSW 350 - subwoofer
    Pioneer Elite Big Screen
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    I had a 4ES that woud run SDA1C with no issues. I don't consider that the gold standard but its a testament to the build quality at the very least. The transformer is one of the larger iron cores I've seen in my usual travels. This is the last model year that the ES line really impressed me as the next evolution of them(STR-DA1000ES+) just stinks and continues to this day.
    3 Zones? 6.1 with full component video support, great parametric EQ for you control freaks, DTS ES and PLII, multi-channel input/output.....just to rattle off some obvious features. $250? Good lord.
    I would estimate shipping in CONUS to be around $30 w/ insurance.
  • shawn474
    edited March 2008
    Bump....with some new information:
    Sony STR-DA5ES Digital Receiver
    Employing three 32-bit processors, this rock-solid receiver provides ultra-precise surround decoding for Dolby Digital EX, DTS-ES, and Dolby Pro Logic II, plus Sony's Virtual Matrix 6.1 and Digital Cinema Sound modes. For maximum purity with analog signals (like the output from an SACD player), stereo, 5.1-channel and 7.1-channel analog direct modes bypass all DSP.
    Read More
    The STR-DA5ES boasts some serious amplification, too: 110 full-bandwidth-rated watts x 6; wide-range response out to 100kHz (great for SACD); high-linearity power capacitors for smooth, expressive audio; and a high-capacity power supply. The sixth channel of power lets you hook up a back surround speaker to complete a seamless 360° soundfield.
    You also get a versatile 2-way LCD remote that puts control menus, radio station names, and CD titles (from compatible Sony changers) right in the palm of your hand. And three-room, three-source capability means you and two other housemates can all enjoy different sources simultaneously in different rooms. There's even a dedicated remote for the second room!
    And check out the impeccable ES construction: frame-and-beam chassis, short signal paths, eight channels' worth of 192kHz/24-bit D/A conversion, non-linear heat sink fins to fight resonance — attention to every detail, inside and out! It even has an RS-232C port to enable future upgrades!
    Details:
    * Dolby Digital EX, DTS-ES, Dolby Pro Logic II, Virtual Matrix 6.1, and Digital Cinema Sound
    * DTS Neo:6
    * three 32-bit processors for surround decoding
    * 3-room/3-source capability (A/V preamp out for 2nd room; stereo speaker out for 3rd room)
    * learning/multibrand 2-way LCD remote with macros
    * separate remote for 2nd room
    * 110 watts x 6 into 8 ohms (20-20,000 Hz) at 0.05% THD
    * 6.1-channel and 5.1-channel inputs
    * 6.1-channel preamp output
    * RS-232C port
    * digital inputs: 4 optical, 2 coaxial
    * component video switching: 2 in, 1 out (50 MHz bandwidth)
    * 4 audio, 5 A/V (including 1 A/V behind the flip-down front panel, and 5 S-video) inputs
    * optical digital output
    * 192kHz/24-bit DACs
    * 6.1/5.1/2CH analog direct
    * on-screen display
    * aluminum front panel
    * Sf (S-fin) heat sinks
    * Control A1ii and Control S
    * 16-15/16"W x 6-7/8"H x 18-7/8"D
    * Weight: 20kg (44 lbs)
    * warranty: 5 years
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • jtgranby
    jtgranby Posts: 887
    edited March 2008
    Shawn is great to deal with A++ Polkie.
    JT
  • shawn474
    edited March 2008
    Edited.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    edited March 2008
    AM, to be honest I am not familiar with the 2ES. Maybe someone else who has experience with both could chime in and give some help.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • capitan100
    edited March 2008
    I've owned and still own several Sony ES receivers. I have not owned the 5ES but I have heard it and have read a lot of information on it. It is one of the best ES receivers out there, and for the price that Shawn is selling this for, it is one heck of a steal. I'm just surprised this is still available. I just purchased the DA7ES because I wanted 7.1, otherwise I would be all over this.
    I truly believe this would be a significant upgrade versus the 2ES. I upgraded my HT system with the DA7ES replacing my V555ES receiver and it is a HUGE difference in sound quality, especially in SACD, HT and music. You can do some research over at agoraquest.com. There is a lot of information on the DA5ES.
    RT2000i - Fronts
    RT1000i - Surrounds
    2 Channel Room
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
  • shawn474
    edited March 2008
    Thanks, capitan. Appreciate the info. :)
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    edited March 2008
    Final bump......off to e-bay this weekend! (or I just may keep it!)
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Hi All,
    first post here. I post at the agoraquest site and the DA5ES is considered one of the best receivers made by Sony.
    I am interested in this receiver. Could you tell me what the shipping cost
    would be to Lynn Ma. 01904.
    ~Peter
  • shawn474
    edited March 2008
    I am not absolutely positive, but from past experiences with double boxing and insured shipping, it would be close to $50.00. This receiver alone weighs 50 lbs!!!!! I'll work up a quote and let you know for sure sometime tomorrow as I am going out of town this afternoon and will not be returning until early tomorrow am.
    Thanks,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Hi Shawn,
    Thanks for your fast reply. Will the original box be included?
    ~Peter
  • shawn474
    edited March 2008
    No, I unfotunately do not have the original box. I have A LOT of boxes, stryrofoam and bubble wrap to use to make sure it ships safely. I have sent quite a few electronics in my day and to date none have been damaged. Be sure that I will pack it VERY securely.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Shawn
    Could you contact me by email. Being a new member here I do not
    have any way of contacting you directly.
    ~Peter
  • shawn474
    edited March 2008
    You can reach me at:
    shawnhendi@yahoo.com
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Thanks Shawn
    I sent you an email.
    ~Peter
  • shawn474
    edited March 2008
    Well, did some thinking. I am going to keep this for a secondary system. Not for sale anymore.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Hi Shawn,
    I know your doing the correct thing by keeping the DA5ES. It is a great amp.
    Also I saw your post on agoraquest and you will find a lot of good information about your receiver.
    ~Peter
  • Neskahi
    Neskahi Posts: 297
    edited March 2008
    But if you change you mind, I'll take it.
    SDA 2.3/RDO's... xovers by Ben
    SDA 2.3TL/Stock..
    SDA 1C/Solens/RDO's [gave to my Uncle]
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    M91 x 2 Pioneers/C91 Pre
    Yaqin MC10l
    DCD-1520/1560/2560 Denon
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Neskahi
    Neskahi Posts: 297
    edited March 2008
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2008
    Neskahi wrote: »
    Good one!
    It looks like he changed his mind again?
  • shawn474
    edited March 2008
    Dave,
    That was posted yesterday; just haven't deleted it yet. Trust me; it's staying. But thanks for the investigative reporting.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • DollarDave
    edited March 2008
    I didn't do the investigating, your potential buyer did. I just misinterpeted the date because I have been working for about 30 hours...
    Carry on.
  • shawn474
    edited March 2008
    No problem at all. Just wanted to clear up anything that might have been seen as misleading or dishonest - anyone here who knows me understands that I am not that way. Although I almost bit on the guy from Nigeria who was going to send me a check for $500 and have his movers pick up the receiver at my house. LOL!!!!! If in the future I decide to sell this, Peter (greekeyes) has first right of refusal.
    Thanks,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Thank you Shawn.
    ~Peter
  • Neskahi
    Neskahi Posts: 297
    edited March 2008
    Did not mean to sound prosecutorial.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2008
    Excellent AVR, I just recently sold the one I owned as well.
  • greekyes
    greekyes Posts: 7
    edited March 2008
    Shawn
    I'm glad that you and Steve were able to properly set up your DA5ES.
    When I am able to obtain a DA5ES the information that was exchanged between
    the two of you will be of great help to me when I set up mine.
    ~Peter
  • shawn474
    edited March 2008
    Peter,
    Steve's a good dude and the info. he gave me was spot on. The AVR has never sounded better. I didn't feel like the return was worth it for me to sell it. It's worth more to me than I would have gotten for it. I watched the Polkfest DVD that I got from Sal again and it is crazy how much different a properly calibrated system sounds. I am ultimately happy that I decided to keep it, but also enjoy trying new things. I'll get the itch again, but PROBABLY won't get another AVR until it decodes the new formats and has HDMI (although I'm not really sure why :D).
    Although, the Cambridge 540 that Doro is selling is calling my name........ ;)
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    edited July 2008
    Putting this back on the market. With the purchase of the Outlaw 950 and the B&K AV5000, it would be a shame for this to sit unused. It is a stellar HT AVR and is in absolutely beautiful condition. Asking price is still $250.00. If someone is interested, I'd be happy to split shipping charges for the polkies.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
