Need some opinions
cfrizz
cfrizz Posts: 13,415
edited March 2008 in Electronics
Hi guys. I'm trying to help out my supervisor. He needs to update his receiver & has asked me for an opinion.
He is looking at a Pioneer Elite VSX-91THX http://www.electronicexpress.com/product?prod_id=12031
It looks good to me. He wants to make sure that he can utilize it to get all the benefits out of his HD tv & cable box & whatnot.
He is also wondering what the benefit is of running the video through the receiver & how it would work?
What would be the simplist & most effective way of getting the best picture out of his setup.
Are there any problems with this machine & what other receivers in this class would you recommend?
Thanks fellas.:)
Post edited by cfrizz on
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2008
    Should work just fine. Plenty of component/hdmi inputs to work with.
    The benefits of using the AVR as a video switcher is that you don't have to change the input on the TV, which can make using multiple devices easier. Without it, you'd have each device hooked directly to the TV and you'd have to change the TV's input to the one associated with the device you're currently using.
    If you have a good universal remote it could do that for you, and some of the benefit of using the AVR as a switcher goes away. But I still think it's a nice convenience that makes the system easier to use.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2008
    go with the newer 92 model, the 91 had some issues with LFE, that were fixed in the 92 model.
    F1nut Posts: 52,297
    edited March 2008
    Make sure he gets one that has 200 wpc.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2008
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • amulford
    amulford Posts: 5,020
    edited March 2008
    What kind of speakers does he have, Cathy?
  • cfrizz
    edited March 2008
    :D Very funny wiseguy!:p
    I just told him that whatever receiver he gets should have preouts FOR 200WPC!:p:D
  • cfrizz
    edited March 2008
    He has some Cambridge Soundworks bookshelf system/w sub. He doesn't know the model numbers.
  • amulford
    edited March 2008
    Sounds like he's more interested in the video. That looks good.
    The best is to go direct into the tv, you don't have the receiver in the chain.
  • daboyz
    daboyz Posts: 5,207
    edited March 2008
    amulford wrote: »
    +1 on that
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited March 2008
    I used to run all my sources through a Sherwood Newcastle P965 pre/pro and now that I have sold it my picture is much more grainier. Granted I have a cheap TV.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • tcrossma
    edited March 2008
    To me, picture quality doesn't suffer at all by going through my AVR. Maybe it makes a difference for others. To me audio quality is far more important, so maybe that's part of it -- maybe I'm just not as picky about video. But HD looks amazing, as does SD DVD playback.
