What does this mean??
DannyD
DannyD Posts: 133
edited March 2008 in Electronics
I recently purchased a used Marantz MM9000 amplifier. In the manual it says this for the input level control on the back of the amp for each channel:
When you use the MM9000 in a THX system the knob must be set to THX Ref (maximum position). Do I have a THX system and if so or not how do I figure this out? Right now I have the knobs set a little more then halway.
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • strider
    strider Posts: 2,568
    edited March 2008
    From what I recall, in order to get a THX certification for an amp there can't be any attenuation of the signal at the amp. I'm assuming it's so the levels of the channels are all correct based on the output of the pre amp/processor.
    Personally, I don't worry about THX certification of equipment. It's not a guarantee that it'll sound good. I would run the system with the input level knobs of the amp maxed out, and use the pre amp to control the volume level.
    Wristwatch--->Crisco
  • jayman_1975
    jayman_1975 Posts: 672
    edited March 2008
    Well if your theatre seats and your rack aren't THX certified but your gear is.... then your totally screwed. You don't want to mix.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • hockeyboy
    hockeyboy Posts: 1,428
    edited March 2008
    None of your gear is THX certifiable except your amp so don't worry about it.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • dorokusai
    dorokusai Posts: 25,638
    edited March 2008
    Keep the inputs at THX Ref unless you have level problems. Forget about it in regards to THX.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2008
    Thx?
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited March 2008
    One good aspect of "THX Certification" is, and I could be mistaken about this, is that it makes things a little more honest in the ratings.
    If two AVR's are rated at 110 watts/channel, and they're both "THX Certified", then that means with ALL channels driven, not "Two channels driven under a full moon at high tide ..... on the 2nd Tuesday of the month".
    It should make it easier to compare apples with apples, oranges with oranges.
    I think. I could be wro.... slightly incorrect on that.
  • hockeyboy
    edited March 2008
    I am so used to being lied to that doesn't help me. Russ I spit up my beer when I saw that picture.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
