What does this mean??
DannyD
I recently purchased a used Marantz MM9000 amplifier. In the manual it says this for the input level control on the back of the amp for each channel:
When you use the MM9000 in a THX system the knob must be set to THX Ref (maximum position). Do I have a THX system and if so or not how do I figure this out? Right now I have the knobs set a little more then halway.
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Post edited by DannyD on
From what I recall, in order to get a THX certification for an amp there can't be any attenuation of the signal at the amp. I'm assuming it's so the levels of the channels are all correct based on the output of the pre amp/processor.
Personally, I don't worry about THX certification of equipment. It's not a guarantee that it'll sound good. I would run the system with the input level knobs of the amp maxed out, and use the pre amp to control the volume level.Wristwatch--->Crisco -
Well if your theatre seats and your rack aren't THX certified but your gear is.... then your totally screwed. You don't want to mix.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
None of your gear is THX certifiable except your amp so don't worry about it.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Keep the inputs at THX Ref unless you have level problems. Forget about it in regards to THX.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thx?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
One good aspect of "THX Certification" is, and I could be mistaken about this, is that it makes things a little more honest in the ratings.
If two AVR's are rated at 110 watts/channel, and they're both "THX Certified", then that means with ALL channels driven, not "Two channels driven under a full moon at high tide ..... on the 2nd Tuesday of the month".
It should make it easier to compare apples with apples, oranges with oranges.
I think. I could be wro.... slightly incorrect on that.Sal Palooza -
I am so used to being lied to that doesn't help me. Russ I spit up my beer when I saw that picture.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
