Bllu-Ray and HDMI receivers???
NeilGabriel
I think I get that I need a receiver with HDMI to get the best AQ from BR discs (unless the player has an internal decoder for them and I can use the mutli-channel outputs)). My question is, does the receiver need HDMI AND its own internal decoder for the newest DD and DTS. A lot of receivers have had HDMI for a while, but I assumer they don't have internal decoders for the newest audio formats.
Post edited by NeilGabriel on
Not to HJ, but to add, what is the major diff. between reg DD and DTS and the new formats. I'm thinking about getting a new AVR as well.
I am not an expert, but there seem to be only a few on the market that have the codecs to process the new formats. The Integra pre/pro is the most popular and I think there is also an Onkyo carbon copy of it. If I am correct, just having HDMI is not enough to get all the new formats.
Venom -
You need HDMI 1.3a (some have 1.1 or 1.2). The only internal decoding Blu Ray player is the Panasonic BD-50 which isn't out yet. If you wait for that you can use 6 RCA cables for lossless sound, or buy a newer receiver and use HDMI and a capable Blu Ray (more to choose from if they don't have to do the decoding). You still have to find one that supports the feature though.TV Samsung 61" 1080P DLP LED
TV Samsung 50" 1080P DLP
HD-DVR
Receiver Yamaha RX-V663
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
I got into a lively discussion with cheddar recently regarding issues related to this. Check out this thread for alot of info:
http://www.polkaudio.com/forums/showthread.php?t=63888
But you don't need an HDMI receiver to get the best possible audio.
You can get a blu-ray player to transcode the DD,DTS into PCM and that is transmitted over HDMI (1.2) and then the receiver can do the DA conversion to analog. The one caveat here is that the player will need to support the codecs, and most don't support DTS-MA.Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D -
Right the Panasonic BD-50 is the only one to support it without HDMI.....TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
The last I saw was an April release date for this but Crutchfield says they have no date. Any ideas out there?? -
...and most don't support DTS-MA.
Yes DTS-HD Master Audio is a curve ball. I'm in the HDMI 1.2 boat right now so I'll be waiting for more affordable players with all the decoders to send via PCM. I'm not upgrading my receiver again anytime soon.AVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE] -
NeilGabriel wrote: »The last I saw was an April release date for this but Crutchfield says they have no date. Any ideas out there??
That sounds about right (April) from what I've seen on AVS. Since I had to upgrade my receiver anyway I went ahead and got the 1.3, but this Panny is a good option. I think I'll pick up the BD-30 when the 50 comes out now that the LFE issue is fixed with a firmware upgrade. Hopefully the price will drop with the new one and my receiver will do the decoding.TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
Looks like the Sony BDP-S550 (Fall '08) is going to decode DTS Master Audio and Dolby TrueHD with 7.1 analog out.
http://www.news.com/8301-10784_3-9877956-7.html?tag=moreAVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE] -
Hopefully by then Sony will have proper firmware to get the PS3 codes up to DTSMA par.TV: Hitachi P42H401
DVD Player: Sony Playsation 3
XM Tuner: polkaudio XRt12 Reference Tuner *SOLD*
Console: Nintendo Wii
Cable: Tivo Series II DVR *SOLD*
Receiver: Onkyo 705
Amps: (3) Outlaw M200
Center: polkaudio CSi5 *SOLD*
Fronts: polkaudio RTi12s *SOLD*
Sides: polkaudio RT8s *SOLD*
Rears: polkaudio RT8s *SOLD*
Sub: Invisible
