Bllu-Ray and HDMI receivers???
NeilGabriel
NeilGabriel Posts: 1,487
edited March 2008 in Electronics
I think I get that I need a receiver with HDMI to get the best AQ from BR discs (unless the player has an internal decoder for them and I can use the mutli-channel outputs)). My question is, does the receiver need HDMI AND its own internal decoder for the newest DD and DTS. A lot of receivers have had HDMI for a while, but I assumer they don't have internal decoders for the newest audio formats.
Post edited by NeilGabriel on
  • Willow
    Willow Posts: 11,339
    edited March 2008
    Not to HJ, but to add, what is the major diff. between reg DD and DTS and the new formats. I'm thinking about getting a new AVR as well.
  • venomclan
    venomclan Posts: 2,467
    edited March 2008
    I am not an expert, but there seem to be only a few on the market that have the codecs to process the new formats. The Integra pre/pro is the most popular and I think there is also an Onkyo carbon copy of it. If I am correct, just having HDMI is not enough to get all the new formats.
    Venom
  • lockmart
    lockmart Posts: 107
    edited March 2008
    You need HDMI 1.3a (some have 1.1 or 1.2). The only internal decoding Blu Ray player is the Panasonic BD-50 which isn't out yet. If you wait for that you can use 6 RCA cables for lossless sound, or buy a newer receiver and use HDMI and a capable Blu Ray (more to choose from if they don't have to do the decoding). You still have to find one that supports the feature though.
    TV Samsung 61" 1080P DLP LED
    TV Samsung 50" 1080P DLP
    HD-DVR
    Receiver Yamaha RX-V663
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • fumoffu
    fumoffu Posts: 80
    edited March 2008
    I got into a lively discussion with cheddar recently regarding issues related to this. Check out this thread for alot of info:
    http://www.polkaudio.com/forums/showthread.php?t=63888
    But you don't need an HDMI receiver to get the best possible audio.
    You can get a blu-ray player to transcode the DD,DTS into PCM and that is transmitted over HDMI (1.2) and then the receiver can do the DA conversion to analog. The one caveat here is that the player will need to support the codecs, and most don't support DTS-MA.
    Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D
  • lockmart
    lockmart Posts: 107
    edited March 2008
    Right the Panasonic BD-50 is the only one to support it without HDMI.....
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • NeilGabriel
    edited March 2008
    lockmart wrote: »
    The last I saw was an April release date for this but Crutchfield says they have no date. Any ideas out there??
  • Bamadude
    Bamadude Posts: 245
    edited March 2008
    fumoffu wrote: »
    ...and most don't support DTS-MA.
    Yes DTS-HD Master Audio is a curve ball. I'm in the HDMI 1.2 boat right now so I'll be waiting for more affordable players with all the decoders to send via PCM. I'm not upgrading my receiver again anytime soon.
    AVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE]
  • lockmart
    lockmart Posts: 107
    edited March 2008
    That sounds about right (April) from what I've seen on AVS. Since I had to upgrade my receiver anyway I went ahead and got the 1.3, but this Panny is a good option. I think I'll pick up the BD-30 when the 50 comes out now that the LFE issue is fixed with a firmware upgrade. Hopefully the price will drop with the new one and my receiver will do the decoding.
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • Bamadude
    Bamadude Posts: 245
    edited March 2008
    Looks like the Sony BDP-S550 (Fall '08) is going to decode DTS Master Audio and Dolby TrueHD with 7.1 analog out.
    http://www.news.com/8301-10784_3-9877956-7.html?tag=more
  • nodeuces
    nodeuces Posts: 96
    edited March 2008
    Hopefully by then Sony will have proper firmware to get the PS3 codes up to DTSMA par.
    TV: Hitachi P42H401
    DVD Player: Sony Playsation 3
    XM Tuner: polkaudio XRt12 Reference Tuner *SOLD*
    Console: Nintendo Wii
    Cable: Tivo Series II DVR *SOLD*
    Receiver: Onkyo 705
    Amps: (3) Outlaw M200
    Center: polkaudio CSi5 *SOLD*
    Fronts: polkaudio RTi12s *SOLD*
    Sides: polkaudio RT8s *SOLD*
    Rears: polkaudio RT8s *SOLD*
    Sub: Invisible :(
