Monster Cables Vs....
lanion
lanion Posts: 843
edited March 2008 in 2 Channel Audio
My Iron Man training/charity blog.
HT:
32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
Post edited by lanion on
«13
  • Face
    Face Posts: 14,340
    edited March 2008
    That's great!
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    Gizmodo really needs to check their sources. Anyone click on the Audioholcis link? I looked at the thread for 5 mins, the poster has 7 posts, the post in question is a response to a thread on diminishing returns for speakers.
    The guy goes on and on and is completely off topic for most of his post. He describes his system in extreme detail including his 50k 750lb speakers that are diy by his PhD acoustical engineer brother, as well as his custom 450lb subwoofer. The poster is a 61 year old PhD himself who drives a lexus.
    As for the testingtThey did a blind test with only 5 trials with music none of them have ever heard before. When asked for pics of his amazing gear he gives his life story instead. I don't buy a word of it.
  • lanion
    lanion Posts: 843
    edited March 2008
    HT:
  • Road Runner
    Road Runner Posts: 106
    edited March 2008
    I don't know about coat hangers, but I think they proved with ABX testing that all cable sounds the same unless the length is really long in which case you need thicker cable. Some cables go for something like, I don't know, maybe $500 a foot in the really extreme cases. So some people might be spending 2000 times too much on something.
  • chargerman426
    chargerman426 Posts: 419
    edited March 2008
    lanion thats one of the funniest thing ever. So is going to get people to stop spending outrages amounts of money on cables think they will make a huge difference. Now cables make make a tinny difference but can anyone really say that its worth 1400 dollars for copper wire.
    If life had more tubes it would be a lot smoother.
  • venomclan
    venomclan Posts: 2,467
    edited March 2008
    It cannot be proven, sound quality is too subjective. As far whether cables make a difference, yes they do. As you climb the ladder into better and better gear, the more difference it makes. Cables, I/C's and power cables do make a difference in my system.
    Venom
  • Ferres
    Ferres Posts: 310
    edited March 2008
    Skeptics always argue it's purely psychological due to price and aesthetic factors. But I've tested $50.00 cables that out perform $400 cables. So pricing aside, cables do make a difference but you really have to find the good ones hidden under the hype.
    Many reviews are unreliable. You have to listen for yourself and spend quite a bit of time listening to get accustomed to what is there and what is lacking in you favorite tracks. Preferably CD's with multiple instruments on the bkgd.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • madmax
    madmax Posts: 12,434
    edited March 2008
    As you listen to different wires you notice different signatures. Thats a fact. Price doesn't always tell the story but often it does. Lets face it, you can get a decent but cheap piece of wire, dress it up nicely and ask whatever price you want. It won't sound better than the same piece of wire without all the dressup. On the other hand, certain wire designs can sound much better than the standard off the shelf roll of wire.
    madmax
    Vinyl, the final frontier...
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2008
    I guess I can't use my "then just use coat hangers" joke anymore...LOL
  • Road Runner
    edited March 2008
    I don't remember exactly what they did with those ABX tests with the cables, they may have not been the best tests. One thing that provides pretty good evidence that there's no difference comes from the times that they trick someone and say they changed the cable, but they really didn't. Listeners will claim that they're hearing all these differences in sound, but there's no way they could because the cable was never changed. The only difference is the listener believes that the cable was changed. Another thing that makes it seem like there's no difference is that the differences that people claim to hear are not differences that could be caused by a difference in the cable, like a larger soundstage which supposedly can only be caused by differences in speakers or things like the SDA effect. But I'm not really clear on all that. Same people claim to notice differences in the "visual" presentation of sound with tube amps, so who knows.
    heiney9 Posts: 25,408
    edited March 2008
    I know. Cables make a difference in my rig, PERIOD. If you haven't tried it you aren't credible to speak about it. Try it, then come back and speak about experience not conjecture. Not trying to flame you, but you write as if you are just basing your opinion on "other" peoples experiences. Try it yourself.
  • Face
    Face Posts: 14,340
    edited March 2008
    heiney9 wrote: »
    Thank you for putting this into words better than I could.
    I wish cables didn't matter, it would have saved me a lot of money. :D
  • Yashu
    Yashu Posts: 772
    edited March 2008
    The coat hangers should sound better. Direct soldered connection. Point to point is always better than a connection made by nothing but friction.
    That is not what I find funny though, the funny part is not that coathangers sound as good as Monster, but that Monster, as usual, is proven to be nothing but marketing.
    Try some real cables and then do the test. I am not going to say they will sound better or worse, but there should be a difference. Everything makes a differece. Monster is average at best, so apparently are point to to point coathangers.. Home depot heavy duty extension cord should sound better than Monster when used with proper connectors. Monster is fueled by marketing. Those of us that are in it for the music aren't afraid to say we have solderd coat hangers, or Home Depot cable, or really any strange tweak or thing, as long as it sounds good. We will spend 10 dollars or 1000 dollars as long as it sounds better. Some people use this stuff as a status symbol. Bose, Monster, Apple, etc, these are status brands. The average person will tell you they are the best, where as the educated person knows there is better, but not always based on price.
  • steveinaz
    edited March 2008
    You know, as much as using a bunch of coat hangers to rig up my system sounds wonderful and thrifty, I think I'll stick with Kimber. ;)
  • venomclan
    edited March 2008
    I can't afford the coat hangers, especially if they are THX Certified. How do paper clips work?
  • Yashu
    Yashu Posts: 772
    edited March 2008
    I don't know, ask Amar Bose?
    edited March 2008
    steveinaz wrote: »
    Problem is coat hangers are manufactured with "pot metal". Very poor audio transfer properties compared to long grain multi-strand copper or "star" quad type configuration.
    Even if I could wire my rig with coat hangers I wouldn't do it.
  • Road Runner
    edited March 2008
    Well, a double blind study is more than just conjecture. But, I don't have the link for that, so I can't say how good it was. I imagine it would depend on the type of music that they were playing and the speakers and all that because some might reveal differences more easily than others. Another thing is that they may have used a switching box of some kind and that might reduce the effect of the cable if there was one. Yeah, I never tried it myself, but if I did, I would trust it more if I was able to pick it out blind than if I just noticed a difference when I knew which cables were being used when. For some of the differences in speakers that I've heard, I have no doubt that it's a real difference and that very little if any of the diffence in what I was hearing was psychological. But for subtle differences, I might doubt whether or not what I was hearing was in my mind or in the acoustic signal itself.
  • BottomFeeder
    BottomFeeder Posts: 1,684
    edited March 2008
    I tried some nice cables, hoping & believing that I wouldn't hear a difference.
    Oops. I did.
    "Wish I didn't know now what I didn't know then." Bob Seger
  • steveinaz
    edited March 2008
    heiney9 wrote: »
    You didn't take me seriously did ja bro-hampster? :D
  • jakelm
    jakelm Posts: 4,081
    edited March 2008
    I think this is going to be my new reference pic....
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    edited March 2008
    steveinaz wrote: »
    LOL- No, I forgot the smiley.
  • Road Runner
    edited March 2008
    But it can't be proven?:rolleyes:
    edited March 2008
    Go away and come back when YOU have actually tried it. The proof is in what your ears tell you. If, as you say, you don't trust your ears then leave it be and move on to something else.
    Now you are just stirring the pot for the sake of being difficult. You have no personal experience so your comments about the subject aren't valid. :rolleyes:
  • Road Runner
    edited March 2008
    heiney9 wrote: »
    Nope, my comments are still valid because there's no reason to believe that people who have done the double-blind tests are lying.
    edited March 2008
    It's not about lying it's about perception. Try it yourself. Why is that so hard to do? Plus, I care about what I experience not what others experience when it comes to audio reproduction. One has to be pretty closed minded to read about a few tests and then decide that outcome is absolute.
  • Road Runner
    edited March 2008
    heiney9 wrote: »
    Right, it's about perception. The question is "what is causing a difference in perception?" It could be caused by a difference in the sound waves that are striking the ears because what the speakers were doing is different because the cable is different or it could be caused by something different in the brain because of a different expectation. The important thing is not to just care about the experience, it's to care about the experience and what is causing the experience to be different. It could be in the brain or it could be in the cable.
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited March 2008
    Even if all the tests show the same results? I would say at that point, one has to be closed minded to not even consider that it may be expectation bias that has led to his own beliefs.
    How many DBT's have you participated in? Or don't you trust your ears?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2008
    i now use string, a special twine i found in the garage, its a bit muddled in the bass but the highs are nice.
    Once again we are saved by the newb and their infinite knowledge of all things cabled, the test the test the test, man reminds of that other guy who was here for a while singing the cables dont matter mantra.
    RR use whatever you want on your rig.
    RT1
  • jakelm
    jakelm Posts: 4,081
    edited March 2008
    RT1
    Chicken wire?
    ...with the rust, for sonic reasons..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
