2 channel tube amp suggestions
pmckeealaska
i'm thinking of looking into tube amps and am looking for a suggestion for a 2 channel tube amp to drive my Lsi25's. Any suggestions??
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Post edited by pmckeealaska on
Price points?Political Correctness'.........defined
President of Club Polk -
I am not a tube expert, I am not sure how a 4ohm ompedence works with tubes?
pmckeealaska wrote: »i'm thinking of looking into tube amps and am looking for a suggestion for a 2 channel tube amp to drive my Lsi25's. Any suggestions??
I didn't know too much. But have you considered getting a tube dac or pre-amp to introduce the tubey sound?Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D -
A tube amp driving the LSi25? Jeebus....
I'm sure there amps out there that can do it, but it's probably going to cost you a good bit. I send getting a tube preamp and mating with a good solid state amp - gives you the best of both worlds with those speakers.
While I do prefer an all tube sound with the right speakers, I don't think I could afford to do it with those beasts. They're not only 4 ohms, they're also not the most efficient speakers in the world... -
Any tube amp with a 4-ohm tap on the OPT should work just fine with a 4-ohm speaker.
Transformers were, and are, outstanding impedance-matching devices. That's why McIntosh, e.g., still uses 'em, even on some of their (best) solid state equipment. OK, they use autoformers (i.e., with the primary and secondary windings directly than inductively coupled), but the concept's the same.
As to how much power you'll need for those speakers to satisfy you... I couldn't guess.
