Add amp to Onkyo 605?
NewHTguy
Please forgive my novice question, but can I add an amplifier to an Onkyo 605? There do not seem to be any preouts on the back.
MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s
Post edited by NewHTguy on
No you cannot.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
True, you can't. But look at the bright side!
You got a great receiver for cheap, which means when you NEED more power or a new amp you won't be replacing a $1000 piece of equiptment."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
are there not any high voltage input home theatre amps? I know there are some car audio amps out there that you don't have to have pre-outs to use.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
Thanks for your comments. I just took the plunge and ordered a pair of Rti 10's. Will it help to bi-wire them? Or, should I start saving now for a better receiver?MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
BENCHED: CS20; OWM3s -
jayman_1975 wrote: »are there not any high voltage input home theatre amps? I know there are some car audio amps out there that you don't have to have pre-outs to use.
http://www.listenup.com/lu/merchant.mvc?Screen=PROD&Product_Code=SUPERCHARGER&Category_Code=49702&Store_Code=l"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Probably won't help. Hook them up to your receiver and listen to what you think.
Most people suggest more power for big speakers like the Rti10's. I haven't heard them from an 605 personally but I know they do require quite a bit of power.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
Or you could use something like the Carver Z5 coupler. -
you can still bi-AMP the RTi10's by using 2 sets of wire. One set into the FRONT ports on the receiver, and 1 into the unused surround SIDE ports.
You get MUCH BETTER sound that way"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
ryanjoachim wrote: »you can still bi-AMP the RTi10's by using 2 sets of wire. One set into the FRONT ports on the receiver, and 1 into the unused surround SIDE ports.
Thanks for the advice. I will definitely give bi-wiring a try before I consider upgrading my receiver. Will bi-wiring effectively give the front speakers more power?MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
Maybe. But you have to realize that you are simply trying to ask for more power from the same amp that is already over stressed as it is.
I suggest you watch the volume, you might risk having it go into protect mode & shutting down.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Can't wait for the next post........
"Why do I hear a crackling sound from my speakers?"HT SYSTEM-
lsi 9's -
Tony, ROTFLMAO!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
If you do attempt to bi-wire, please remember to remove the binding post jumpers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the advice. Received the Rti10s today. Decided to let them break in a little before bi-wiring them. While I believe that an amp would improve them, my initial impression is that I can be content without an amp, at least for a while. Of course I said that when I bought my r50's...MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
