Add amp to Onkyo 605?
NewHTguy
NewHTguy Posts: 584
edited February 2008 in Electronics
Please forgive my novice question, but can I add an amplifier to an Onkyo 605? There do not seem to be any preouts on the back.
MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s
Post edited by NewHTguy on
  • cfrizz
    cfrizz Posts: 13,415
    No you cannot.
  • ryanjoachim
    ryanjoachim Posts: 2,046
    True, you can't. But look at the bright side!
    You got a great receiver for cheap, which means when you NEED more power or a new amp you won't be replacing a $1000 piece of equiptment.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • jayman_1975
    jayman_1975 Posts: 672
    are there not any high voltage input home theatre amps? I know there are some car audio amps out there that you don't have to have pre-outs to use.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • NewHTguy
    NewHTguy Posts: 584
    Thanks for your comments. I just took the plunge and ordered a pair of Rti 10's. Will it help to bi-wire them? Or, should I start saving now for a better receiver?
  • Face
    Face Posts: 14,340
    http://www.listenup.com/lu/merchant.mvc?Screen=PROD&Product_Code=SUPERCHARGER&Category_Code=49702&Store_Code=l
  • Rike255
    Rike255 Posts: 131
    NewHTguy wrote: »
    Probably won't help. Hook them up to your receiver and listen to what you think.
    Most people suggest more power for big speakers like the Rti10's. I haven't heard them from an 605 personally but I know they do require quite a bit of power.
    Polk Audio RTi8 Fronts
    Polk Audio CSi A6 Center
    Polk Audio RTi A3 Surrounds
    Polk Audio PSW505 Subwoofer
    Onkyo TX-SR805
    Sony Bravia V5100 46"
    Sony Playstation 3 160GB
    Sony Playstation 3 120GB Slim
  • Danny Tse
    Danny Tse Posts: 5,206
    Or you could use something like the Carver Z5 coupler.
  • ryanjoachim
    you can still bi-AMP the RTi10's by using 2 sets of wire. One set into the FRONT ports on the receiver, and 1 into the unused surround SIDE ports.
    You get MUCH BETTER sound that way
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • NewHTguy
    NewHTguy Posts: 584
    Thanks for the advice. I will definitely give bi-wiring a try before I consider upgrading my receiver. Will bi-wiring effectively give the front speakers more power?
  • cfrizz
    Maybe. But you have to realize that you are simply trying to ask for more power from the same amp that is already over stressed as it is.
    I suggest you watch the volume, you might risk having it go into protect mode & shutting down.
    Can't wait for the next post........
    "Why do I hear a crackling sound from my speakers?"
  • cfrizz
    Tony, ROTFLMAO!!!
  • Face
    Face Posts: 14,340
    If you do attempt to bi-wire, please remember to remove the binding post jumpers.
  • NewHTguy
    NewHTguy Posts: 584
    Thanks for the advice. Received the Rti10s today. Decided to let them break in a little before bi-wiring them. While I believe that an amp would improve them, my initial impression is that I can be content without an amp, at least for a while. Of course I said that when I bought my r50's...
