Without Receiver... PLEASE HELP!!!
cantzme78
I was about to buy the Onkyo 805 and then started reading about all the heat that this thing puts off and that it has actually caused damage to other people's equipment. SO that being said I am wondering about the Pioneer Elite VSX-92TXH which seems to be the comparable model to the Onkyo. I can get the Pioneer for $868 at authorized electronics online. So I guess with my set-up, RTi8's, CSi A6, FXi A4's, and a DSW Pro 500 which is the better receiver? Do I need to fear the 805's overheating? Please help I am without a receiver!!...
There are two types of people in the world, The Ones that do, and the ones that wish they had! What are you?
MARANTZ 7002
RTi8'S
CSi A6
FXi A4'S
HSU VTF 3 - MK3 (IT'S HERE)
PANASONIC 50 IN PLASMA
PANASONIC DMP-BD30
MARANTZ 7002
RTi8'S
CSi A6
FXi A4'S
PANASONIC DMP-BD30
Post edited by cantzme78 on
I have owned and currently own an Onkyo receiver over the last 6 years and yes, they do put off a little heat. More on the newer than older ones because of all the video processing that all receivers to do anymore. I have seen this happen with other brands too including Marantz, Yamaha, Denon, etc. The main thing is with ANY receiver is not to stack anything on top of them and give them ample breathing room. Mine stays about as warm at idle as it does playing movies.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
I have the onkyo and yes it get warm but not burning hotHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100 -
Yesss. Best advice I got from these forums when I bought my Denon was to let it rest alone, and to make sure it had pre-amp outs. I don't have anything stacked on, under or near my receiver, and I've never had any heat issues at all.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
I don't think you're looking for input on the brand, but IMO you can do better in a receiver for $900 - Cambridge, Outlaw, and NAD all have models in that price range, not to mention H/K and Denon, among others
If I got the 805 and put it on the bottom shelf of my stand (only option I have) not sure it would have the most clearence above but it would sit alone. Just don't want to overheat my equipment above..There are two types of people in the world, The Ones that do, and the ones that wish they had! What are you?
MARANTZ 7002
RTi8'S
CSi A6
FXi A4'S
PANASONIC DMP-BD30 -
i am in the same boat. i was thinking of getting the 805, but i read about the heat and lip sync problems on many forums. the heat i could live with, just buy a external fan. I read good things about the Pioneer Elite VSX-92TXH though. Can anybody chime in on this.
I got 805 I dont have any problem with it everything is working fine, I had it for two weeks now and Im not experiencing anything bad so far so good...Front: Tekton Pendragon
Center: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2 -
I also have the 805 and love it!Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
805 rocks!
All receivers run hot, the 805 just runs slightly hotter because it has a very powerful current-driven amp that can be made to run much cooler if you use an external amp.
Many people use the 805 as a Pre/Pro.
Believe me, for under $800, there is nothing that comes close!
