Binding Post Question
lockmart
lockmart Posts: 107
I'm hooking mine up for the first time and will be getting a new receiver. What is the speaker chassis (assume it's the whole assembly that includes the gold plated connectors themselves)? Is it ok to run the wire all the way through the hole and have it touch the other side or do you have to be careful not to let any wire go beyond that hole? I read on another forum you can damage the receiver by letting a wire touch the chassis or the other post but want to make sure I understand it correctly.
Also, would it damage the speakers or just the receiver?
TV Samsung 61" 1080P DLP LED
TV Samsung 50" 1080P DLP
HD-DVR
Receiver Yamaha RX-V663
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB
  • crd2002
    crd2002 Posts: 174
    edited February 2008
    if both post touch you will short out the receiver same applies for the speakers
    Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
    2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    just stick the bare end of the wire a half inch or so, into the hole and screw the binding post down onto it.
    you just do not want the bare wire to touch the other post, or do not let the wire going into the black post touch the red post and vice/versa. Its really simple dont over think it.
    RT1
  • lockmart
    lockmart Posts: 107
    ok so the issue is with touching the other posts not the back of the speaker itself. Either way I'll follow the procedures you mentioned. It's simple I agree, I've only ever owned ones with the cheap clips or Bose so first experience with these nice binding post. Learned something new about speakers in general too.
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • reeltrouble1
    enjoy your speakers and welcome to the club. dont worry, we all started somewhere, its what the forum is for, asking questions and helping folks out.
    RT1
