Shocking
CAvolleyballguy
CAvolleyballguy Posts: 156
edited February 2008 in Electronics
Seriously, My amp is shocking me...
no seriously... Ever since I plugged my amp in yesterday I have been zapped with static electricity by various component attached to my system.
first I got zapped by the corner of the face plate, I wanted to see how warm the amp got after an hour of good use...
I thought that wierd, then I went to eject a dvd from my ps3 which is about 5 shelves below and one column over, and I got zapped pressing the eject button (That has never happened before).
Then I was checking out one of my front speakers and I was wiping away some dust near one of the mid cones and I got tagged by some static electricity, then I went to turn off the amp and when I pressed the off button I got tagged a fourth time and I could see the arc o'pain zap me.
Maybe I should return these fuzzy slippers and silk pajamas to Hammecher schlemmer, or maybe someone can tell me what the Hell is going on here...
seriously I wasnt wearing fuzzy slippers, what the hell is going on here..
ps. the amp sounds great, shockingly clear...
Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
Post edited by CAvolleyballguy on
  • dorokusai
    dorokusai Posts: 25,640
    Get a humidifier in the room.
  • SolidSqual
    SolidSqual Posts: 5,218
    It happens in the winter. Are you wearing slippers. Do you have carpeted floors upon which you and your slippers are walking when you go to change CDs?
  • janmike
    janmike Posts: 6,146
    It's so dry here and I have carpet on the floor to boot. I touch the metal frame of the rack before I touch any gear.
    Michael ;)
    NORTH of 60°
  • CAvolleyballguy
    It is dry in here.. central coast of california but dry..totaly arid. wood floors, rubber reef sandals not slippers...
    I think I am going to buy some giant rubber gloves next
  • ward91
    ward91 Posts: 338
    well i often get shocked if i come into contact with the tv areal and a ground, we recon that its because the tv booster has a floating ground and with interference it just keeps on rising until poor me comes along ,gets woken up after all ready being awake.
    ive being shocked through phono cables and so on but only when i offer a ground path (ie leaning on the corner of a case).
    sounds like you have some major issues (patronising i know).
    perhaps your new amp is the cause by having bad grounding?
    perhaps your new amp doesn’t offer a path to ground whereas your older amp does?
    does your new amp a grounded design or is it double insulated?
    do you have a TT in your system without adequate grounding?
    have you got any very long cable runs that can pick up em interference?
    long areal run going to the amp?
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • George Grand
    George Grand Posts: 12,256
    I discharge myself (electrically) on my daughter or my wife before I touch the stereo. It bugs the **** out of them. I just laugh cause it is great fun.
  • hockeyboy
    hockeyboy Posts: 1,428
    What is your amp plugged into? You typically get more discharge if it is plugged directly into the wall than a power conditioner.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • danger boy
    danger boy Posts: 15,722
    this happen to me most of the winter.. it finally stopped about two weeks ago.. it's static electricity because of the dry season.
    i'd say.. leave your amp on if it zaps you to much ;)
    PolkFest 2012, who's going>?
  • shadowofnight
    shadowofnight Posts: 2,735
    Its the insulating property of the rubber thats causing your problem to begin with....take the sandals off and no socks...problem solved.
    The first rule of Fight Club is you don't talk about Fight Club
  • hockeyboy
    :DI usually strip down naked before I turn on my equipment. Seriously this is not a problem I have at all but have an electrostatic filter on my HVAC system. It makes the air very clean as well so when you build a house make sure you put one in!
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • CAvolleyballguy
    come on shadow.. im only 30, do you think I wear socks with my sandals..
    Well I have a line conditioner coming on monday..so hopefully that solves the problem. For now I have it plugged into a decent surge protector.. but yeah it has to be the amp generating this static charge...never experienced it before...glad It is not a defect with the amp. thanks for the feedback.
  • ShinAce
    ShinAce Posts: 1,194
    If the amp has a connection for ground on the back, use it.
  • shadowofnight
    Haha....That was funny...I bet some of the old farts here on the board are looking down right now at sandals and socks :D
  • BaggedLancer
    BaggedLancer Posts: 6,371
    I don't wear sandals....I have 6 toes on one foot and 4 on the other.
