Thinking of buying RTA 11T
aud10n3wb13
I should have posted it here. I didn't know there was a vintage subforum. Anyways, here is what I posted earlier.
Hi everyone,
I'm new here and it's my first post too.
I was at a speaker store last Saturday . The store had a Polk Audio RTA 11T on sale for $299(out the door price). So I asked the guy if I can listen to it. He placed a cd and I was blown away by the sound quality. However, I found out though that it was more than 15 years old. I looked at the drivers, cabinets and they still look fine. However, I learned this morning during my research that the 2 lower drivers are not really drivers. They are passive radiators. It's also my first time today to hear about passive radiators. So, I'm thinking that I maybe paying for it too much for it.
So folks, I need your guidance if I should buy these floor standers especially I'm on tight budget. The sound was really amazing.
Will this be really good for my home theater? Can I crank it up without hurting my ears? Will it still be lively, smooth, sweet and not harsh?
Can you also please tell me some negatives about this type of speakers so that I can prepare myself when using it for home theater and music?
Any help would be greatly appreciated.
Thanks.
Hi everyone,
Thanks.
Post edited by aud10n3wb13 on
what kind of music do you listen to? $299 isn't to far out there.. but maybe he'll come down in price some.. they are old speakers you know
they are fine speakers.. if they use the SL2000 tweeter. with is more commonly known as a silver coil dome tweeter.. it may sound harsh once cranked up..
and yes.. the bottom speakers are passive radiators.. they provide the bass in vintage Polk Audio speakers.
if they are minty condition.. go for it.. but if you like to listen to music with tons of bass, then they might not be for you.. they prob wouldn't be a good speaker for hip hop or rap.PolkFest 2012, who's going>?
if you like them with your music,,se if you can talk them/him/her down to 200-225 for the pair,,which would be a good deal considering their shape,good luck.JC approves....he told me so. (F-1 nut)
I've had mine for 17 years and love them. I have not found them lacking in bass output. There was a pair in our local craigslists that looked to be in good condition that were listed for $175.MWL
I have a sub which will take care of the bass. I use the sub in movies. I like songs like Alisson Kraus, Jewel, U2, rock and some alternative but not hip hop
I tried haggling the price and he doesn't want to go below $275.
Should I ask him if the tweeter is SL2000? So will this be a good speaker for a home theater? Or should I just go with RTi8? However, I heard that RTi8 are bright speakers.
Thanks guys. -
You can search other posts for these for more info and various comments. You'll see that I and others have commented on them in the past. $299 is too much for these IMHO. I loved them and hey have excellent bass response. Properly amped, you almost don't need a sub, these have a -3db response under 30hz if I remember correctly. Another factor is that if your sub is quite good, then these might be way overkill depending on where you intend to put the crossover point. For $300 there are a lot of used bookshelves (newer and more attractive) to pick from that might hold their value better down the line. As much as I loved them age and style factors is starting to factor in for these. For $200 or less, they're quite good and difficult to beat.
Yes, I've got a decent sub composed of 2 18" drivers. My crossover setting on my yamaha is set at 80hz right now. It's doing well with my bookshelf too. It's just that when I crank up the volume, my bookshelf is hurting my ears. So I was under the impression that going with a floor stander type, I'll be able to experience that even at loud volumes, it's still going to be sweet to the ears, enveloping, as if I'm right inside the concert hall when I close my eyes.
Well the floorstanders have more drivers, so they're going to move more air and be able to get louder and stay cleaner a lot longer than the bookshelves. I don't know how loud you're going, but be sure that it's not your receiver that's the problem or the limiting factor. Most can't go beyond comfortable listening levels without deteriorating sonic quality pretty fast, plus, you run the risk of damaging any speakers large or small by turning a receiver up too high. If you really like loud clean sound, you're going to need an amp in addition to larger speakers. Not to further cloud the issue, but the RTA11t's are very efficient, so they will help you get the most bang for your amplifier buck.
With regards to your question about the rti-8. While I don't have rti-8's, I did purchase rti-12's this past fall and a/b tested them with the RTA-11t's in my home. Now granted my ears have been exposed (conditioned?) to the sounds of the RTA-11t's for 17 years, but I found I much preferred the RTA-11's to the rti-12's. As always, individual preferences vary.MWL
What I'll do today is borrow few speakers from them including RTA 11t so I can audition them at home. As for the receiver, I connected by other bookshelf speaker and it was fine. So looks like it's the other bookshelf that is not capable. For the volume, when I'm watching movies, my yamaha is between -14db to -12db from reference level. So that's about 93db.
if you're really curious about them.. buy them.. use them for a while in your home with your gear. and then decide to keep em or resell them. that's what I do with gear a lot of the times.. get him down to $260 - $275 though..PolkFest 2012, who's going>?
That's really great to hear!
I tried every way yesterday to haggle the price but he wouldn't bring it down.
But I don't want to lose this RTA 11t. Oh, the $299 is actually the out the door price. But yeah, I wish I can get it at <$250. -
you might also want more power for them.. and your Yamaha may not do the job with them.. what was he powering them with in the store?PolkFest 2012, who's going>?
danger boy wrote: »you might also want more power for them.. and your Yamaha may not do the job with them.. what was he powering them with in the store?
Also a yamaha receiver, no amp. But the volume wasn't really loud. -
My yamaha rxv1400 on the manual claims it can do 110watts per channel. But yeah, I should look for an amp in the future.
And am I correct that I should set my receiver as SMALL for the RTA 11? And LFE just to subwoofer and not front+sub?
aud10n3wb13 wrote: »And am I correct that I should set my receiver as SMALL for the RTA 11? And LFE just to subwoofer and not front+sub?
you have to play around with that.. there is not right way or wrong way.. expirement with all settings .. whichever one sounds best.. go with that. one.
i often times switch from small to large on my fronts.. large sounds better for music to me.. while small seems better for home theater movies.
Don't worry about the tweeter right now. I have had my RTA-8T's for 18 yrs with the original tweeter & I like it just fine.
Welcome to Club Polk!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I know a few people have said that $ 300 is too much, however I don't think you can find a nicer sounding set of speakers anywhere for $ 300.
Many people gush over the SL2000 tweeters. I have tried both an am far happier with the SL 1000 that comes with the RTA 11T.
Keep in mind the RTA 11TL came with the SL 2000's as standard. I have met people who own speakers marked as being RTA 11T's that were actually TL' models so that might be worth looking into. You can tell the difference by looking at the tweeter.
My vote is to buy them and enjoy. -
Just left the store and I brought home the 11ts and Paradigm mini monitors. I tried the rt11s again before I left the place and sound was really phenomenal. I'll find out once I get home.
The RTA-11T came with SL2000s, the 11TLs came with the SL3000s. I wasn't a huge fan of the harshness the SL2000 brings to the table. If I still used mine regularly I would replace them with 194 silk domes.
I like them, but from what I've seen of used ones being sold $300 is as high as you can get and still occasionally find a buyer. Smaller SDA models go for less. -
Sorry guys, it took me so long. I had to bring my son to the doctor. Anyways, it was just few minutes ago that I was able to test the 11Ts. Listened to some music from Boz Scaggs, and it was good. Watched some movies like the bomb chases plane in the movie "The Incredibles". FRONT was set to LARGE and LFE set to BOTH(SWFR+FRONT). The 11Ts was making some clonking noise on heavy LFE. Is this normal? I set to SMALL and replayed the same scene, the sound was still there. I set LFE out to just SWFR and the clonk or plonk sound went away. However, when FRONT was set to LARGE and LFE set to BOTH while I was listening to some music, it was really good.
So what is wrong? So looks like LARGE is good for music and SMALL good for HT?
My volume was at -13db from Dolby Reference Level. My Yamaha master volume is 0 when spl radio shack's needle is at 85db. But I didn't do 0 volume.
The clunking was probably the PR bottoming out. You got it right with movies small, and music large.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
WHEW
I thought something was wrong with her.
I'll do more test. I like her warm sound actually. -
I did more test and I really like the sound. I A/B'd the 11Ts and Paradigm Mini Monitor. The Minis sounded as if the person talking had a cloth covering his mouth. My Paradigm Atoms even sounds better than the Minis. However, the sound from 11T were somewhere in between warm and natural. I really like it. And I have a strong feeling that once I finish my theater and treat the room, the 11Ts would totally rock.
Oh, that other speaker on the stand is Panasonic 6ohm speaker. I took it from my wife's component radio.
It actually does sound good. The Atoms was previously my mains and now it's acting as my surround speakers.
I took some pictures of them. The 11T had few dings but not major. The grills were near perfect but had some dust. The cabinets were intact. The foot and its plastic veneer was coming off though. It's not major since it's not part of the cabinet. I'm really lucky because the previous owner really took care of it pretty well. By the way, sorry about the mess on my future home theater room.
Quick question guys. I'm driving the 11Ts with my Yamaha RXV1400(110watts/channel). They really really sound good!!! My wife finally agreed with the sound quality when she went down the basement. We listened to a live concert from Sandi Patti and she just wowed.
Anyways, will I gain better audio if I power them with another amp? I mean, the output from my Yamaha receiver will be sent to the amp, then the 11Ts will be hooked up to this amp. If so, I saw another thread last night who mentioned about a cheap amp but does so well. I think it was Sonic being sold at Amazon. Are those really good?
Thanks. -
No. you should look at Adcom, or parasound.
This would be an excellent choice for you
http://www.polkaudio.com/forums/showthread.php?t=63955
Search the for sale thread here. Polkies take pretty good care of Poilkies.
Or check craigslist.com to find something local. Does your Yami have PreOuts?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The T-Sonic wouldn't work well with those speakers are high volume levels. IMO, I wouldn't use one for anything nut nearfield listen with small speakers. You need a high current amp. Check out www.audiogon.com and look around."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ben, you beat me.
I believe the unit does have pre outs.
http://www.yamaha.com/yec/products/productdetail.html?CNTID=200213&CTID=5000300&ATRID=1010&DETYP=ATTRIBUTE"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I will check later for the PreOuts. I really haven't paid attention to the back of my receiver.
I'll keep you posted. -
LOL, I answered to the wrong thread. hahaha. So yes Ben, my yamaha have preouts for fronts, surround and surround back.
So is the the one where I connect the amp? What benefit do I get when I drive the mains with an external amp(like adcom) rather than driving them with my Yamaha?
