Question about my DSW Pro 600
ryanjoachim
ryanjoachim Posts: 2,046
Just a random question...
I have the Onkyo 605(B) receiver. One of the options in the speaker setup is "Double Bass". Here is how I set my bass up:
I turned the volume up as high as I dare to get it on the sub itself (I have no idea how high it can go, since Polk didn't include a display or gauge for volume).
Then I turned the sub "db" on my receive to -15(max). From there I slowly turned "up" the db until I got the bass sound I was looking at.
Here is my question: Without "Double Bass" enabled, even at high volumes the Polk sub sounds either WAY under-powered, or it sounds really bad and distorted.
Am I doing something wrong? Granted, I have no clue what I'm doing when it comes to HT setup, so any advice would be great.
Thanks!
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • izafar
    izafar Posts: 822
    edited February 2008
    Hi ryanjoachim,
    Just set your sub's volume control at half way point and then do the audessy auto setup.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • ryanjoachim
    That's the problem...on this sub there's no way to know where the "half-way" point is. There's no gauge, knob, level monitor...nothing.
    Just a light that blinks whenever I turn it up. So far I've clicked like 15 times and the light keeps blinking the same as when I turn it down.
    Am I missing something here?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
    treitz3 Posts: 20,276
    No promises as I don't have the same sub, but the # of blinks and the speed in which they blink determines what volume the sub is at. It should be discussed in the owner's manual.
    Also, it would be recommended to refer to your owner's manual on you AVR to make sure thayt you have the sub hooked up correctly and then to make sure that the settings within the AVR are correct.
  • hoosier21
    hoosier21 Posts: 4,432
    page 10 of the manual does discuss the front LED blinking to indicate the volume. Read it :)
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • ryanjoachim
    I'll read that, thank you.
    Now, just to check...I have a digital coax cable going from the LFE spot on my sub to the sub input on my receiver...does that sound like a proper way to do it?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • hoosier21
    use a cable with RCA connectors on each end, an normal audio cable, I am sure this is what you meant, not a digital coax.
    Connect the RCA interconnect cable from the receivers "LFE out" or "Subwoofer "out" to the subwoofers LFE input.
    What receiver are you using?
  • ryanjoachim
    I'm using my Onkyo 605(B)
    And it actually is a Digital Coaxial cable (the audio variety)
    And my sub only has 1 "Sub" input. Just a single input, not 2 like RCA.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • Ron Temple
    Ron Temple Posts: 3,212
    Wow, the blinking light volume control is perhaps the worst design feature of the Velodyne DPS series. I'm really surprised that Polk chose to copy it. Supposedly, this was a request put in by CC so that their sales reps could easily demo the unit (Velo).
    An SPL meter is essential for you to be able to tell what gain to set your sub.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • ryanjoachim
    Well, the sub is sounding pretty good right now, but that's WITH "Double Bass" on. Without it on the sub seems...weak. Would the low pass knob have any impact on that?
    BTW...what the heck IS the low pass filter for?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • DeusExa
    DeusExa Posts: 491
    Wonder how it would compare with a Hsu VTF-1 or the likes...
  • hoosier21
    You are using the subwoofer out on the receiver, so you should set the low-pass filter on the subwoofer to it's highest setting.
    A low-pass filter is a filter that passes low-frequency signals but attenuates (reduces the amplitude of) signals with frequencies higher than the cutoff frequency.
    Hey, just a thought, read the frigging manual, full of good information.
  • TroyD
    TroyD Posts: 13,124
    Aren't we cranky today.
    BDT
  • ryanjoachim
    I read parts of the manual...but like I said, a lot of the fancy words and such go right over my head.
    I can build a computer from scratch, but I can't set up a damn sub...
    story of my life!
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • hoosier21
    TroyD wrote: »
    BDT
    eff you
  • J_Kennedy
    J_Kennedy Posts: 138
    TroyD wrote: »
    BDT
    No he's not cranky (well I don't know, maybe he is :D ) but I assume you're comment is directed to his about reading the manual? If so, it was good advise. The questions keep coming and with each one it's becoming more clear that he hasn't read the manual and isn't well versed in setting it up; he's missing some fundamental knowledge. For example, asking what low pass is after configuring it using incorrect methods and maybe even doing things that could damage the sub or AVR. It's becoming very clear that reading the manual is very good advise.
    It's good constructive advise that the OP shouldn't be offended by and should appreciate the value in.
    - Onkyo TX-SR805
    - Polk RTi8's Main L/R's
    - Polk CSi A6 Center
    - Polk FXi3 Surrounds/Rear Surrounds
    - HSU VFT-2 MK3
