Room Eq Wizard (REW)
jakelm
Just an update to inquire on who is still using it.
Question: Calibrating the Rat Shack meter is fairly simple since HTS has a cal. already to import. But, has anyone tried any other mics? Is the analog rat shack working out ok you? How often do you calibrate?
I was thinking about using the mic that came with my HK. How well would it work?
Po
Just a few questions to throw out there....:p
Jake
Po
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Post edited by jakelm on
Rat shack meters can vary by up to 2 dB from reference, if memory serves me right.
Try any mic you can get your hands on. -
I know, but the nice ppl at HTS provided a calibration that can be installed along with REW.
I might give my HK mic a tryMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
What do you all think? And how can I get the REW to measure above 8khz?
This is taken in stereo w/subMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
This is taken in Logic 7ch cinema surroundMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Logic 7 w/ -5 tiltMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Still cant figure out how to get it to read passed 8khz:mad::mad:Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
By the look of your graph, that should be the least of your concerns."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Waterfall logic 7Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Help? What are your thoughts?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Play with phase and placement till that nice dip from 60-80 gets better."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
LOL...I just checked, my subs xover was turned to 40hz... THE WRONG WAY>>>>:eek:Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I was just about to say the same thing. That dip from 60-80 Hz shows up consistently.
The graph is not as bad as you might think. You would get a better idea of the dips and peaks by using a linear scale for frequency.
There also seems to be a dip from 200-300 and a very narrow dip around 500 Hz. What kind of room treatments do you have(carpet, blinds, sound panels, etc...)? -
Thats from the HK auto Eq.
Dont know what to do about the dip @~500hz.
Room treatments?????
Lets see, hmmmmmmm, the wife put curtains, added a love seat and another recliner. Carpet floors. Thats about it...lol
No treatments.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
That's plenty of treatment for an average room.
I have plaster ceilings, hardwood floors, and no rugs.
The dip above 500 Hz is so narrow that you would be wasting time trying to track it down. Move the speakers a few inches or play with the toe in to see if that changes it. -
With everything, carpet and all, I have very little, if any, reflections. My biggest problem is valted ceilings, but its not so bad.
Adjusted sub xover and toed in the 7's just a bit. The responce is much better in stereo, but in Logic 7 surround, I'm still getting a dip around 500 and spikes around 5khz. I cant measure above 8khz, so I dont know about the top end.
Will keep playing with it....Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Do your speakers have a crossover point at 500 Hz? Are the 7's three ways?
That could be it, but I doubt it.
Can you do a near field test? Have the mic 1" from the driver you are testing(woofer or tweeter) and run the same test at a low volume. This can help determine if the dip is from the speakers or room reflections. -
The only speakers I have in use that have a crossover @~500 are the mid bass drivers in the small surrounds. The Polk monitor 7's are 2 way.That could be it, but I doubt it.
I doubt it as well...Can you do a near field test? Have the mic 1" from the driver you are testing(woofer or tweeter) and run the same test at a low volume. This can help determine if the dip is from the speakers or room reflections.
I will run it in 2 channel stereo and uplug the left then right speaker for individual speaker calibration.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
After much headache, I was able to accomplish this. I sure stepped in a big pile of doo doo,:eek: getting started with this calibration....
Keep in mind, the HK and the RS mics are not trust worthy above 12khz.
In both graphs, I used the HK's mic. I did install the RS mic calibration, but to me, the HK's mic still did a better job.
...or I could be dreaming..:o
The first graph is PllxII with 1/3 octave (blue)
The second is Stereo w/ .5 octave. (yellow)
Take into mind, that my sub is tuned too low, so adjustments will be made there,,,,
I dont think I can fix that dip between 800hz and 1500hz, without modding the crossover or buying a Eq,Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
That actually looks pretty good(for a real-world graph).
Thanks.... Cause thats where I live...in the real world...:p
The guys over at home theater shack, are very knowledgable, but they are telling me its not right because of the mic I used and the way I calibrated everything. They said I should run the mic to the Line In instead of the Mic In.
But when I do that..things get screwy between the mic and the Pc.
I'm so confused....
Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I have a DIY sub too
I also Have the BFD, but I haven't really got into it yet. I am waiting to get my new LR so I can look at the cross over range too.
Anyways, I looked at the the shack a bit myself, and have been meaning to get into REQ too. Did you do the loop back configure of the of the line out and line in?Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D -
The loop t loop, is to calibrate the soundcard, cant calibrate without.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Just a small update.
After tweeking it abit, I have a graph, from 10hz - 500hz, the bass to midbass region. I have learned the RS metere is not reliable beyond 1khz.
This is taken with a 1/1 scale. I usually look at a 1/3 scale but this scale give a better peeks and nulls.
The sub is xo'd at 120hz while the mains are @ 80hz, after some phase issues, I think it came out pretty well. I know it sounds alot better now.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
So how much EQing did you end up with?Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D
No Equ'ing, just simple adjustments like phase and HK's xover settings. I have no eq in the mix. Actually I do not own an eq.
That graph is in 2 channel stereo. 7's and sub.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
^reported"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
If your going to sweep a room do it one speaker at a time not all at once. For a sub set the range to 10 too 200hz. For the mains set it to 10 to 20000hz and then run them one at a time. The Radio shack sucks both low and high and the mic that came with your avr may work but you don't have a Cal file for it so again not a good choice.
It did look like you have some of the issues fix post the file for your sub I want to look at the it and if you post a file other's can run it on there system.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1
