Room Eq Wizard (REW)
jakelm
jakelm Posts: 4,081
edited December 2012 in DIY, Mods & Tweaks
Just an update to inquire on who is still using it.
Question: Calibrating the Rat Shack meter is fairly simple since HTS has a cal. already to import. But, has anyone tried any other mics? Is the analog rat shack working out ok you? How often do you calibrate?
I was thinking about using the mic that came with my HK. How well would it work?
Po
Just a few questions to throw out there....:p
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • ShinAce
    ShinAce Posts: 1,194
    edited February 2008
    Rat shack meters can vary by up to 2 dB from reference, if memory serves me right.
    Try any mic you can get your hands on.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    I know, but the nice ppl at HTS provided a calibration that can be installed along with REW.
    I might give my HK mic a try
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    What do you all think? And how can I get the REW to measure above 8khz?
    This is taken in stereo w/sub
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    This is taken in Logic 7ch cinema surround
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Logic 7 w/ -5 tilt
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Still cant figure out how to get it to read passed 8khz:mad::mad:
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    By the look of your graph, that should be the least of your concerns.
  • jakelm
    jakelm Posts: 4,081
    Waterfall logic 7
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Face wrote: »
    Help? What are your thoughts?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    Play with phase and placement till that nice dip from 60-80 gets better.
  • jakelm
    jakelm Posts: 4,081
    Face wrote: »
    LOL...I just checked, my subs xover was turned to 40hz... THE WRONG WAY>>>>:eek:
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    I was just about to say the same thing. That dip from 60-80 Hz shows up consistently.
    The graph is not as bad as you might think. You would get a better idea of the dips and peaks by using a linear scale for frequency.
    There also seems to be a dip from 200-300 and a very narrow dip around 500 Hz. What kind of room treatments do you have(carpet, blinds, sound panels, etc...)?
  • jakelm
    jakelm Posts: 4,081
    Thats from the HK auto Eq.
    Dont know what to do about the dip @~500hz.
    Room treatments?????
    Lets see, hmmmmmmm, the wife put curtains, added a love seat and another recliner. Carpet floors. Thats about it...lol
    No treatments.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    That's plenty of treatment for an average room.
    I have plaster ceilings, hardwood floors, and no rugs.
    The dip above 500 Hz is so narrow that you would be wasting time trying to track it down. Move the speakers a few inches or play with the toe in to see if that changes it.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    With everything, carpet and all, I have very little, if any, reflections. My biggest problem is valted ceilings, but its not so bad.
    Adjusted sub xover and toed in the 7's just a bit. The responce is much better in stereo, but in Logic 7 surround, I'm still getting a dip around 500 and spikes around 5khz. I cant measure above 8khz, so I dont know about the top end.:confused:
    Will keep playing with it....
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    Do your speakers have a crossover point at 500 Hz? Are the 7's three ways?
    That could be it, but I doubt it.
    Can you do a near field test? Have the mic 1" from the driver you are testing(woofer or tweeter) and run the same test at a low volume. This can help determine if the dip is from the speakers or room reflections.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    The only speakers I have in use that have a crossover @~500 are the mid bass drivers in the small surrounds. The Polk monitor 7's are 2 way.
    I doubt it as well...
    I will run it in 2 channel stereo and uplug the left then right speaker for individual speaker calibration.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    After much headache, I was able to accomplish this. I sure stepped in a big pile of doo doo,:eek: getting started with this calibration....
    Keep in mind, the HK and the RS mics are not trust worthy above 12khz.
    In both graphs, I used the HK's mic. I did install the RS mic calibration, but to me, the HK's mic still did a better job.
    ...or I could be dreaming..:o
    The first graph is PllxII with 1/3 octave (blue)
    The second is Stereo w/ .5 octave. (yellow)
    Take into mind, that my sub is tuned too low, so adjustments will be made there,,,,
    I dont think I can fix that dip between 800hz and 1500hz, without modding the crossover or buying a Eq,
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    That actually looks pretty good(for a real-world graph).
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    Thanks.... Cause thats where I live...in the real world...:p
    The guys over at home theater shack, are very knowledgable, but they are telling me its not right because of the mic I used and the way I calibrated everything. They said I should run the mic to the Line In instead of the Mic In.
    But when I do that..things get screwy between the mic and the Pc.
    I'm so confused....:confused::confused:
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • fumoffu
    fumoffu Posts: 80
    I have a DIY sub too :) I also Have the BFD, but I haven't really got into it yet. I am waiting to get my new LR so I can look at the cross over range too.
    Anyways, I looked at the the shack a bit myself, and have been meaning to get into REQ too. Did you do the loop back configure of the of the line out and line in?
    Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D
  • jakelm
    jakelm Posts: 4,081
    fumoffu wrote: »
    The loop t loop, is to calibrate the soundcard, cant calibrate without.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Just a small update.
    After tweeking it abit, I have a graph, from 10hz - 500hz, the bass to midbass region. I have learned the RS metere is not reliable beyond 1khz.
    This is taken with a 1/1 scale. I usually look at a 1/3 scale but this scale give a better peeks and nulls.
    The sub is xo'd at 120hz while the mains are @ 80hz, after some phase issues, I think it came out pretty well. I know it sounds alot better now.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • fumoffu
    fumoffu Posts: 80
    So how much EQing did you end up with?
  • jakelm
    jakelm Posts: 4,081
    fumoffu wrote: »
    No Equ'ing, just simple adjustments like phase and HK's xover settings. I have no eq in the mix. Actually I do not own an eq.
    That graph is in 2 channel stereo. 7's and sub.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    EndersShadow Posts: 17,704
    ^reported
  • Phasewolf
    Phasewolf Posts: 514
    If your going to sweep a room do it one speaker at a time not all at once. For a sub set the range to 10 too 200hz. For the mains set it to 10 to 20000hz and then run them one at a time. The Radio shack sucks both low and high and the mic that came with your avr may work but you don't have a Cal file for it so again not a good choice.
    It did look like you have some of the issues fix post the file for your sub I want to look at the it and if you post a file other's can run it on there system.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
