Help with Onkyo upgrade
johnnytex
I own a Onkyo HT-S990THX Home Theater in a box. I have purchased a Onkyo TX-SR705S to upgrade the receiver.
My old system had the following Polk speakers; RT600, CS400i, FX300i.
I was wondering if I should use the old Polk speakers or keep the much smaller but THX certified ones that came with the HTIB?
Any advice is greatly appreciated.
Post edited by johnnytex on
I vote for the Polks.
Welcome Johnny!
Keep the Polks! They will trounce any HTIB that is made. Once you get it all setup you will love it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Hook them both up and see what you think. I would think the Polks would be better, but that opinion is not based on first hand knowledge. I wouldn't pay any attention to the THX certification.Things work out best for those who make the best of the way things work out.-John Wooden
I also have some spare HTIB speakers laying around....I replaced them with polks and never looked back...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
+1, best way to decide is to listen for yourself. I agree with everyone else you'll probably decide on the Polks, but there's only one way to find out.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
Onkyo is not famous for their speakers. ;-)"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
I just upgraded my my reciever and my front and center. I have the onk 705 and the RTi8s and the CSi3 and i love it so far, im replacing a Yamaha HTIB and its looking amazing and sounding better
The 990 is said to be not worthy of being called a HTIB, but pro reviewers. It's that good. But, it's not "that" good and the Polks will likely "trounce" the Onkyo's, and I agree, you need to listen for yourself.
I also agree, Onkyo isn't known for the speakers, well actually they kinda are....but not for having good speakers.
- Onkyo TX-SR805
- Polk RTi8's Main L/R's
- Polk CSi A6 Center
- Polk FXi3 Surrounds/Rear Surrounds
- HSU VFT-2 MK3 -
I believe it's the receiver that is THX certified not the speakers.TV Samsung 61" 1080P DLP LED
TV Samsung 50" 1080P DLP
HD-DVR
Receiver Yamaha RX-V663
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
Speakers can be as well. If they pass certain tests which I have no idea what they are.Polk Audio RTi8 Fronts
Onkyo TX-SR805
