Surround speaker placement question
I have a question about speaker placement for my surrounds on my angled walls. My home came w/ a 380 sq. ft. unfinished bonus room so I decided to turn it into a home theater. I just finished putting up the sheetrock, mudding, sanding and all that fun stuff. I pre-wired the room before I put up the sheetrock for 2 side and 2 back surround speakers. My problem is my side walls go up at an angle after about 4 ft. The ceiling is about 8 ft high. I've read that the best place to put side surrounds is a couple of feet above the seating area pointing directly over the seating area. But if I put the speakers higher than 4 ft the angled walls will face the speakers down toward the seeting area. I currently have the side speaker wire coming out of the walls at the top of the flat area which is about 4 ft high. I was wondering if anyone knows what the best setup would be. Leave them at 4ft where the speakers would be level or move them up higher and have the speakers angled down? Since my room was prewired I really can't do much experimentation without tearing up the wall. Thanks for any advice!
Post edited by mcjudd on
I don't see any reason you have to make the choice... there is absolutely no reason whatsoever - at least in terms of the physics of construction - why you can't locate the speakers on the angled part of the wall but still have them facing horizontally. Perhaps the room dimensions prevent you from doing so - maybe the speakers would stick out too far or something. But if this is a dedicated listening room, just do it.
Easy would be two wooden triangles mounted to the wall that create a vertical surface on which to mount the speakers. Adding a shelf to hold the speaker would also be easy and would serve. Probably easier yet would be two metal brackets. They'd come bent at 90 degrees.. but just change the angle.
If you change your mind about cutting sheetrock, you could create cubbies that at least partially hold the speakers and get them back out of the way.. a simple shelf at the bottom of each cubbie would serve to hold the speaker.
Bottom line.. I don't see you have to choose. -
I have considered some type of speaker shelf but I'm worried it might need to come to far out on the wall to make the speaker level. I guess I'll have to look at that when I get my speakers. I was thinking of getting some used ls/fx surround speakers and since they have sound coming from the sides instead of the front would it matter if they were pointed down?
I have always liked the idea of tower speakers set up on a low solid platform. I have used this technique with success in my setup. Maybe it is not everyones cup of tea.
I just purchased an Infinity Entra Two Center channel speaker for the top my television which is surrounded by two Entra Three towers sitting on the floor. I have two more Entra Three towers for my left and right surrounds which I have aimed at each other. I then took the CS400i Polk 250 watt center speaker and placed it between the surround Entra Three tower speakers on the floor facing directly upwards. Maybe those sound waves are crashing into each other in the back and diffusing all over the place. The Polk center was too powerful in the front center position as all the other speakers are 150 watt. I am now in hog heaven. The Polk really works well in this position and I can adjust my Onkyo 600 receiver to 0 setting for all speakers, except for the subwoofer, which is set to -3 per Doctor Specs directive. Ooooooo, ahhhhhhhh."Time will tell the tale"
Onkyo 600 AV Receiver
Subwoofer - Velodyne CHT-12
Fronts - Infinity Entra 3 towers
Center Front - Infinity Entra Two
Surrounds - Infinity Entra 3 towers
Surround Center - Polk CS400i -
WWW. DOLBY.COM HAS MANY DIAGRAMS OF SPEAKER PLACEMENT
TO GIVE ONE THOUGHTS OF AIMING AND BOUNCING SOUND WAVES. I LIKE TO LET MY EARS BE THE GUIDE."Time will tell the tale"
bensontm
I notice you have a Velodyne CHT-12. I am still deciding on a sub-woofer, so was wondering ... when you bought the CHT-12, did you also consider the VLF-1012. What was the difference. What made you pick the CHT-12.
Thanks ............. MichaelJMains: RTA15T
Front Center: CSi40
Surrounds: FXi50
Sufwoofer: Definitive Tech SuperCube I
Audio: Onkyo TX-SR600
HDTV: Mitsubishi 55" wide screen -
The CC where I purchased my Velodyne has a limited selection of speakers and amounts of speakers that they stock. They only carried the CHT-12 and CHT-15.
I have been satisfied with the CHT-12 although I would definitely compare when given the opportunity.
Apology for not having futher information on the comparison.
I thought of stacking two CHT-12's on top of each other if the CHT-12 goes on sales. Presently the CHT-15 is on sale although I thought it would not be a good thing to stack a CHT-12 on top of a CHT-15 because of the sound save differences. I have limited space on top of everything else. My CHT-12 is six feet in front of my listening area to the left of my television. The CHT-12 does give quite performance at this range for the money.
Anybody else have comments on stacking these subwoofers and whether there is a law of diminishing returns on the benefits of moving to two subwoofers instead of one?"Time will tell the tale"
Thanks for the information bensontm.
Is your subwoofer placed near the corner in your room? Why would you stack two subwoofers rather than placing one on each side of the room, or just buying one larger one.
Also, if you are looking for more subwoofer advice, I think there is a sub-woofer forum in clubpolk.Mains: RTA15T
Front Center: CSi40
Surrounds: FXi50
What about getting a pair of outdoor speakers (as the come which brackets) and mounting them horiziontally on the angled part? I've seen it done and they worked well.
just another option if it hasnt been offered yet. if you want in wall speakers, you could use some sort of a shim ( a fabricated block that would help angle them towards your seeting position)
in all acuallity if it was on an angled cieling with a nicly shime speaker set up it may look pretty nice. i think at least in my mind it does. -
Shims would be a problem, due to the fact that the brackets are configured for drywall thicknesses. I think that it is a workable idea, but will require some custom fabrication along with it.That's cool also, makes your system look like it had more love
Polk makes an aimable tweeter for their inwalls, thats a nice feature for installation oddities.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
MichaelJ
Polkie
bensontm
Re: Can only say that I am satisfied with the CHT-12.
Yes, you just click on Forums at the top of the page and scroll down the page and you will see subwoofer & basemanagement? I have a post there about this issue. Also, subwoofers are speakers.:o"Time will tell the tale"
