Onkyo 805 HDMI problem
edossin4
edossin4 Posts: 105
edited February 2008 in Electronics
Ok heres one for you....................
I use my DVD for DVDs and CDs. Its an Onkyo DV CP704. I use the HDMI output to the receiver. If I play DVDs no problem. When I try to play CDs the HDMI output on the player starts going in and out and displaying error messages. The only way to fix this is to turn on the TV.
I want to get this set up to remove the step of turning on then turning off the TV just to listen to CDs. I have tried connecting the optical output in addition to the HDMI output but that doesn't work either.:confused:
Onkyo Tx sr805
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Panasonic 54" rear projection
Direct HDTV DVR
PS3
Post edited by edossin4 on
  • WilliamM2
    WilliamM2 Posts: 4,811
    Go into setup, and make sure the HDMI output to the TV is set to: Audio Out "no", or "off".
    billbillw Posts: 8,100
    If William's suggestion doesn't work, make sure you have that optical cable routed to a different input. ie: HDMI to DVD input, optical cable to CD input, (go to digital in assignment in setup menu). Then you should easily be able to listen to CDs over optical without worrying about HDMI handshake issues.
  • steveinaz
    steveinaz Posts: 19,546
    Ed Zachry Bill.
