Dumb question of the day...
DannyD
DannyD Posts: 133
Hi
I'm new to home audio and separates. Interested in buying an external amplifer. The question is...What type of cable is needed to go from the receiver preouts to the external amplifier inputs? Thanks in advance for your help!
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited February 2008
    RCAs, or XLR dependent on your source. Looks like RCAs, if you are using the receiver listed in your sig...
  • DannyD
    DannyD Posts: 133
    What is an XLR cable?
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • Face
    Face Posts: 14,340
    Your HK only has RCA's.
  • Sherardp
    Sherardp Posts: 8,038
    DannyD wrote: »
    XLR CABLE - An analog audio cable normally used to connect microphones,amplifiers, etc to professional audio devices. It has three pins and provides a balanced input, as opposed to an unbalanced or single-ended RCA connector. See pics below 1) Balanced IC 2) Unbalanced RCA
    By the way, SignalCable offers real good quality cables over the Monster stuff, worth a try.
  • obieone
    obieone Posts: 5,077
    Thank you. I was needing that answered as well.
  • vonnie123
    vonnie123 Posts: 326
    DannyD wrote: »
    Hi
    A good question to know up front. If you choose a multi-channel amp, you will need one RCA (for unbalanced) to RCA for each channel run from AVR pre-outs to the external amp. Welcome to the forum.
  • danger boy
    danger boy Posts: 15,722
    get some good RCA's and hook that sucka up. ;)
    PolkFest 2012, who's going>?
