Dumb question of the day...
DannyD
Hi
I'm new to home audio and separates. Interested in buying an external amplifer. The question is...What type of cable is needed to go from the receiver preouts to the external amplifier inputs? Thanks in advance for your help!
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Post edited by DannyD on
RCAs, or XLR dependent on your source. Looks like RCAs, if you are using the receiver listed in your sig...
Bill Ayotte wrote: »RCAs, or XLR dependent on your source. Looks like RCAs, if you are using the receiver listed in your sig...
What is an XLR cable?Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Panamax MP-5300 Power Conditioner -
Your HK only has RCA's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
XLR CABLE - An analog audio cable normally used to connect microphones,amplifiers, etc to professional audio devices. It has three pins and provides a balanced input, as opposed to an unbalanced or single-ended RCA connector. See pics below 1) Balanced IC 2) Unbalanced RCA
By the way, SignalCable offers real good quality cables over the Monster stuff, worth a try.Shoot the jumper.....................BALLIN.............!!!!!
Thank you. I was needing that answered as well.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Hi
A good question to know up front. If you choose a multi-channel amp, you will need one RCA (for unbalanced) to RCA for each channel run from AVR pre-outs to the external amp. Welcome to the forum.[ -
get some good RCA's and hook that sucka up.
PolkFest 2012, who's going>?
