New Speaker Cable, 12g or 14g?
SBTx
Hello everyone, new Polk guy here!
Just purchased the RTi8's, CSi3, and FX A4 yesterday and had a question regarding speaker cables. My room is only 14x10 and I was wondering if it'd be overkill to purchase 12g wire over 14g since the size of my room is so small. I was looking at the 12g or 14g monoprice cable, I hear good things about it in terms of the cost/quality.
My Home Theater:
Samsung LCD LN-T5265F
Onkyo 805
Speakers
RTi8
CSi3
FX A4
PSW12
Xbox w/ HD-DvD
Playstation 3 60g
Onkyo 805
Speakers
RTi8
CSi3
FX A4
PSW12
Xbox w/ HD-DvD
Playstation 3 60g
Post edited by SBTx on
Hi and welcome
I can't believe there is much cost difference. But in that size room you probably couldn't tell the difference. 2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Don't waste your money 14g will do the job just fine. Your runs will be short enough.Dan
I'd run 10 AWG on the fronts, 12 AWG on the rest of the setup. Though the difference is subtle, I like high quality 10AWG on my fronts. Oh well, either of your choices will serve you well, check out bluejeans cables also.Shoot the jumper.....................BALLIN.............!!!!!
On just a receiver it don't really matter much. I'd say your fine with the 14ga.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The difference in sound will probably be negligible over shorter runs, but unless the cost difference is significant (to YOUR pocketbook), go with the heavier 12g."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
For the fronts smaller gauged wire works just fine. In fact I'm running 16AWG for my fronts. The wires are about 10 feet long. For the surrounds though bigger is probably better 12 or 14 depending on how far you need to run the wires.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
I think I'm gonna purchase a 100' spool of monoprice cable (12g). Its about 25 bucks and the reviews/feedback seems pretty positive, anyone use(d) this speaker wire?My Home Theater:
Onkyo 805
Speakers
RTi8
CSi3
FX A4
PSW12
Xbox w/ HD-DvD
Playstation 3 60g -
Not trying to hijack your thread...but I hate to open another topic about the same subject.
I need to run two 30+ft runs for in-ceiling speakers. I had planned on using 14g...but do you guys think I need to up that up to 12g? I am going to use the in-wall speaker cable...to avoid any interference. Thanks... -
spaceace414 wrote: »Not trying to hijack your thread...but I hate to open another topic about the same subject.
14ga will be fine for 30 feet. In-wall wire does not stop interference, it just has a special jacket and insulation that does not put off hazardous fumes when it burns. It is required to meet building codes. -
Hi Bill. I am in a better mood today. Sorry about the other day. I get a little passionate about my work:oPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Here is a link to an article I used for determining the wire gauge.
http://www.roger-russell.com/wire/wire.htm#wiretable -
Make note that table is geared at "the resistance of the speaker wire not exceeding 5% of the rated impedance of the system." .
If you wish for the wire to account for even less resistance, a bigger wire is fine. Just because the chart says 16 ga is fine doesn't mean you can't use 12 ga. -
This is true but what gains to do get from the larger guage wire? I don't see any reason to have such a large guage wire that doesn't do anything better then it's thinner 14 or 16 guage wire will get done. If you take ego out of it and think about getting a job done, you may think differently about having such heavy guage wire.
I once thought as you do.Dan
Using a larger wire allows lower resistance from the amp to speaker. This results in better damping.
If you want to know, I'm running 16 ga for my fronts and 14 ga for my sub. Length runs are 20 feet and 3 feet.
If someone just spent $5k on speakers and has $250 devoted to cable, let them spend what they want. Just because 14 gauge is going to work, doesn't mean they can't get something bigger in the hopes of upgrading or not having to mess with it later.
Please, tell me, how do I think? The only opinions I've posted in this thread are in the paragraph above this one. -
I am pretty much a newbie at this. So what you guys are saying is that if I am doing this project myself, I can just use normal speaker wire and not worry about the "in-wall" stuff? That will save me $15....it's not much but it will make the wife happy. -
spaceace414 wrote: »I am pretty much a newbie at this. So what you guys are saying is that if I am doing this project myself, I can just use normal speaker wire and not worry about the "in-wall" stuff? That will save me $15....it's not much but it will make the wife happy.
No, if you are putting the wires into a wall, ceiling or crawl space, get the "in-wall" CL-rated type of speaker wire. Blue Jeans Cable has great stuff. -
dan when I went with 8 guage and magic boxes things sounded better. sure anything over 14 guage or even 16 in his case is overkill but so what? I like looking at my phatty wires and I love the way they make my 2-ch rig sound.
parts express has nice CL-3 carol cable at good prices. I have used it and its great for HT application's.
RT1 -
What are the general rules about which gauge of cable to use for specific applications?
Instead of asking such a broad question which always seems to go into a debate, can you please explain what you are trying to accomplish and ask for specific advice?
There should be less to read and we should be able to assist you in your specific needs. Thank you.
OK, I am trying to drive speakers that run at 4 Ohms. The speakers are LSI 9's, and the cable will run about 35 feet, mostly behind my walls. The receiver is a Denon DRA-395. I will mainly be listening to FM and CD's. -
12 gauge would be my choice, due to the 4 ohm load.
How hard is it to work with the Blue Jeans 12 white? I'm thinking about ordering some to wire my surrounds. I would love to keep everything Signal, but it's pricey for 45 foot runs! Is the 12 gauge going to be too thick to route through the walls and attic?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
