Anyone leave their amps on all the time
pearsall001 wrote: »Turn mine off at the end of the night. Krell recommends to "NOT" leave them on 24/7. I'll take their word for it.
I used to leave my Krells on all the time, plugged into the same outlet as my pool pump...:D -
I turn mine off whenever I am done using it.
You had Krell gear before!!! How'd you like it!!
:cool: -
Nope mine are off until TURNED ON!:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Deadof_knight wrote: »Nope mine are off until TURNED ON!
Everyones are off till they are turned on.:pPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I leave all HT amps on all the time.
engtazengtaz
I leave them on the whole time Im listening to em, then i turn em off.
It messes with my spidey sense if i leave something powered up and not in use.
DaveOnce again we meet at last. -
Amp & Pre in standby mode all the time, except when I go away for long periods of time.Michael
NORTH of 60° -
Used to leave mine on until a sudden thunderstorm took out my beloved Carver TFM-45 a few years ago. Now it's all unplugged until it's listening time.Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
OK thats one for YOU BEN !
On another note so hows that SonoEARTHQUAKE Sub sounding these days now that it really broken in.
Finally got my Dayton HPSA-1000 they other day:cool: " He who dies with the most equipment wins Right ? "
I always left mine on.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Mine pulls about 500-600 watts at idle. I turn it off if not using it. (and yes, I also turn off a 60 watt light when I leave the room - so I'm cheap)
pearsall001 wrote: »You had Krell gear before!!! How'd you like it!!
:cool:
They were great on Thanksgiving, if I ran out of burners on the stove I would just fire up the pair and have extra cooking space for the world famous Venom's Yam Magnifique; Delish.
Michael
The manual claims 140watts at idle. No amp pulls 5-600 at idle unless true Class A.
I leave mine on so that when we lose electricity in an ice storm, the power company feels a huge financial hurt when I'm off the grid and they rush right over to get me back online first...............it pays to consume.;)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote: »The manual claims 140watts at idle. No amp pulls 5-600 at idle unless true Class A.
When I spoke with the service department for my amplifier, I asked them and was told 500-600watts at idle.
Looking at Cinepro.com for the latest version of my amp (the Mk. 4 - more powerful than my Mk. 1 so not an apples to apples comparison) it lists the Power Consumption as 5,550 watts under test conditions and 2,700 watts under Nominal Conditions. (no idea what that means)
I do not have a manual for my amp so I do not know for sure what it is supposed to draw. Is there a way I could go about measuring it with a volt-meter? If so, how would I go about it?
Try out one of these.....http://www.p3international.com/products/special/P4400/P4400-CE.html
Amazon has it for $22.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
You can't power either of them off the switched outlet, they draw too much current. The outlet is rated 1A max.
WOW!
It took 26 posts to get to this? -
Michael
Your amp pulls 4-5 amps at idle? -
Like I said, not really sure - anyone have a belkin PF-60 I can borrow??
I have a voltmeter, is it as easy as sticking it in the plug and see what it draws?Mains.............Polk LSi15 (Cherry)
Current clamp and then measure/calculate.I do not have a manual for my amp so I do not know for sure what it is supposed to draw. Is there a way I could go about measuring it with a volt-meter? If so, how would I go about it?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Some Multi-Meter's have a 0-10 amp scale that can be measured directly
through the leads. You have to plug the leads into that scale on the meter to use it correctly.. What brand and model of meter do you have.SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
my switched mode d-sonic amp stays on - belkin pf60 reads 0 @idlemy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
You can use a voltmeter, but you'll have to cut a wire. That's not the answer you were looking for, so that leaves a clamp-on AC ammeter.
Ammeter is not a typo, so lay off me. -
Deadof_knight wrote: »OK thats one for YOU BEN !
And it wouldn't have blown if it was turned off. Yes it is slightly more likely to blow if turned on, but a lightning strike near by is likely to blow it if turned off;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
