finally got me a sub!! but need some help!
margate21
margate21 Posts: 105
hi all,
i finally ordered and received my svs sb+ sub. i live in an apt, so it will probably turned on very low. but I need help with the eyes glazing over options on the back. i just need basic starting points. everytime i try to read the info on the dials my a.d.d steps up. this is the last piece i needed to my system. (started upgrading in may 2007) :D
any help woulld be must welcomed!!
Thanks,
margate21
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+
Post edited by margate21 on
  • mark090852
    mark090852 Posts: 999
    edited February 2008
    Are you referring to the SVS SB12-Plus?
    It's a great sub. I had one and was very happy with it.
    Here are some ideas for starting points:
    Gain turned approximately 1/3 clockwise from lowest point
    Auto/on set to Auto
    Parametric EQ Level set to min
    Phase set to 0
    Crossover disabled (set the crossover in your Onkyo avr)
    Room Comp You'll need to calculate room volume. Room's length X width X ceiling height = volume of room in cubic feet. Set Room Comp dial to small if less than 1400 cubic feet, medium if 1400 - 2400, or large if above 2400.
    These settings will get you up and running. I'd recommend getting a Radio Shack SPL meter and eventually calibrating the sub to the other speakers in your set-up.
    Ask questions as you become more familiar with the different options and settings. I'd be glad to help.
    Mark
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • margate21
    ok so i hooked it up and ran audessy. firstly, for some reason it set my speakers to full, should it not be set so i can control the crossover points? secondly, i dont feel any vibration from the sub.. should i feel something if i put my hand in front of the sw? i have never had a sub before so all this is new.
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • margate21
    bump....
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • mark090852
    When the sub is connected properly and a low bass scene plays on your DVD you're going to feel it big time. A good example is in "Finding Nemo". Play the "Darla" scene where she taps on the aquarium. It's the beginning of chapter 24, 25, or 26. I forget which. Turn the volume up to a comfortable but loud level and enjoy!!! When she taps the glass your walls are gonna shake!!! You'll feel it and hear it!
    You might have to turn the gain up a bit past 1/3 on the back of the sub but don't go over half way up. That's why a SPL meter is nice to have. You adjust the gain to where it matches the output of the rest of your speakers.
