Explanation of a DAC?
halo
halo Posts: 5,619
edited February 2008 in Electronics
Can someone please explain what a DAC is and how it works as if you were trying to explain it to a slow witted child?
What I'm getting at is that if it does what I think it does why do people insist that the source / transport makes any difference what so ever.
If all the 0's and 1's are being run through the DAC, shouldn't a $50 DVD player sound just the same as a mega buck transport?
Where, exactly, in this situation is the difference made, if there is one?
Thanks in advance :)
Post edited by halo on
  • danger boy
    danger boy Posts: 15,722
    little halo, pay attention now... ;)
    this debate about "1's" and "0's" gets nowhere every time..
    the answer is yes.. every transport will sound the same if run thru a DAC. a $50 transport will sound the same as a $2000 transport. there I answered all the questions. :rolleyes:
    bye. end of story, ciao. :D
    PolkFest 2012, who's going>?
  • halo
    halo Posts: 5,619
    not trying to start a debate db. Just wanted an explanation. Thanks for your input. Much appreciated :)
  • dkg999
    dkg999 Posts: 5,647
    I think the quality of the transport debate isn't about the 0's and 1's, but more to do with the pace/timing of the 0's and 1's and the possible read errors in the data stream that the DAC then has to correct or compensate for.
    DKG999
  • halo
    halo Posts: 5,619
    makes sense Doug.
    As to DB's point, I guess the "better" the DAC the better the sound?
  • danger boy
    http://en.wikipedia.org/wiki/Digital-to-analog_converter
    Halo, there are lots of threads on this exact topic.. just like the never ending cable debates....
    anyway. glad I could be of help. ;)
  • Face
    Face Posts: 14,340
    Not all transports sound the same. I'm not saying you have to go out and spend big bucks on one, because sometimes a cheaper one can sound better than a high dollar unit.
  • furball
    furball Posts: 234
    Technically, all a transport does is to extract the ones and zeros embedded in the CD. And a DAC's job is to convert these ones and zeroes to analog electrical signals which can then be amplified to power your speakers, which then becomes the sound.
    So, in an ideal world, this is how things should work. In the real world, it's a bit more complicated. There could be timing issues involved with the data extraction, leading to downstream decoding issues in the DAC, etc. A good DAC is supposed to correct for these problems.
    But in all honesty, CD is a very archaic storage medium.
  • Sami
    Sami Posts: 4,634
    halo wrote: »
    Jitter. Some people claim they can hear a difference but jitter isn't really a problem until you get to more demanding applications. Audio that a human ear can hear isn't really affected by it.
    Again,it is the sum of all parts used,not any single one,as with most things audio.
    " archaic " storage medium......please explain.
  • halo
    halo Posts: 5,619
    Thanks for all the replies :)
  • Early B.
    Early B. Posts: 7,900
    The problem with DACs is -- by the time you buy a decent DAC (let's say $500+) and a good transport (a stand-alone transport, not a CDP or DVDP; if you're gonna do separates, do it right, IMO), you could have purchased a nice CDP for the same piece of money that may sound just as good. With HT, its usually a slam dunk that separates are better than a receiver, but perhaps not so much with a DAC/transport vs. a CDP. In addition, you gotta deal with extra stuff, like cables and power cords that will affect the sound. After a while, it'll make you wonder what link in this chain actually accounts for most of the "improvement" in sound -- is it the DAC, transport, cables, DAC tubes (if any), ICs, power cords, etc.?
    "God grooves with tubes."
  • halo
    halo Posts: 5,619
    Early B. wrote: »
    No offense Early, but that response wasn't very helpful nor did it explain how a DAC works or how or why a dedicated transport is better than a cheap DVD or CDP + DAC.
    Try to remember you are speaking to a slow witted child (me). Thanks.
  • ben62670
    ben62670 Posts: 15,969
    I have been thinking about a DAC when some money comes in. I could use it for say three different transports. Anyone ever use Adcom's older DACs.
    Ben
    Ben
  • halo
    halo Posts: 5,619
    ben62670 wrote: »
    Ben
    Adcom GDA-700 - AGON LINK
  • furball
    furball Posts: 234
    If you want a good DAC, then I recommend the Benchmark DAC1. It is one of the best DAC's out there. Stereophile did a review on it, do a google search.
  • Early B.
    halo wrote: »
    Sorry. I thought db, dkg999, and furball responded adequately to your questions, and since you thanked them for their replies, I was free to ramble.:o
  • Systems
    Systems Posts: 14,872
    dkg999 wrote: »
    Exactly,for the signal to be sent from the transport to the DAC the data and clocks must be combined so they can be transmitted via coax or optical.The DAC then has to precisely separate these signals from each other but small timing errors(jitter) can result.Good DAC's will use sample rate converter chips at their inputs to reclock the data therefore reducing jitter and the influnce of the transport.My DAC uses one of these (a Cirrus CS8420) as the input reciever and I cannot detect any difference in transports be it a cheap DVD or CDP.
    Testing
    Testing
    Testing
  • halo
    halo Posts: 5,619
    So, when using a DAC is it better to use the digital output on the transport or the analog outputs?
  • Face
    Face Posts: 14,340
    You would use the digital out on the transport if you're connecting it to a DAC.
  • halo
    halo Posts: 5,619
    :cool: thanks.
  • danger boy
    halo wrote: »
    With a DAC you HAVE to use the digital outputs from a transport/CDP to your DAC.
    Stand alone DAC's, only have some kind of digital inputs.. toslink, coax, and a few more some times.. then they have a left and right RCA analog outputs that hook up to your receiver.
