Volume Levels for Surround Sound
Should the front be set higher than the rears?
Right now I have my front + center speaker set to +7db as well as my rears set to +7db.
Post edited by bruticus on
Welcome!
    edited February 2008
    if you're hearing to much sound from your rear surrounds, it will sound akward. if your receiver had a auto speaker calibration. use it.. that will set the correct level for each speaker.
    PolkFest 2012, who's going>?
    +7 is alot,try leaving the 3 fronts to 0 and bump up the rears to +2 and see how that sounds to you.
    Go buy an SPL meter from rat shack, and callibrate it correctly.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    jakelm wrote: »
    +1000 it is work the money to set it up right with a SPL meter.
    engtaz
    engtaz
    is it better to turn up the master volume higher instead of having the db levels higher?
    bruticus wrote: »
    Yes. You should shoot for setting your mains at 0db. If after you purchase your SPL meter your rears are too high you can bump them a bit. If you have to bump them say +7db then you should cut your mains to about -3db, and raise your rears to +4db. Raising your DB settings can cause clipping at the line level stage be it a receiver, or a PrePro. When it clips at the line level stage the clipped signal will be amplified. Every Receiver/PrePro is different, but general rule is don't bump it more than +4db.
    BTW welcome to Club Polk
    Ben
    Ben
    just remember, its always better to "cut" than to "gain".
    (usualy)
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
Welcome!
Welcome!
