Volume Levels for Surround Sound
bruticus
Should the front be set higher than the rears?
Right now I have my front + center speaker set to +7db as well as my rears set to +7db.
Post edited by bruticus on
if you're hearing to much sound from your rear surrounds, it will sound akward. if your receiver had a auto speaker calibration. use it.. that will set the correct level for each speaker.PolkFest 2012, who's going>?
+7 is alot,try leaving the 3 fronts to 0 and bump up the rears to +2 and see how that sounds to you.HT SYSTEM-
lsi 9's -
Go buy an SPL meter from rat shack, and callibrate it correctly.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
+1000 it is work the money to set it up right with a SPL meter.
engtazengtaz
is it better to turn up the master volume higher instead of having the db levels higher?
Yes. You should shoot for setting your mains at 0db. If after you purchase your SPL meter your rears are too high you can bump them a bit. If you have to bump them say +7db then you should cut your mains to about -3db, and raise your rears to +4db. Raising your DB settings can cause clipping at the line level stage be it a receiver, or a PrePro. When it clips at the line level stage the clipped signal will be amplified. Every Receiver/PrePro is different, but general rule is don't bump it more than +4db.
BTW welcome to Club Polk
Ben -
just remember, its always better to "cut" than to "gain".
(usualy)ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
http://forum.ecoustics.com/bbs/messages/34579/128211.html
http://www.audiophilia.com/hardware/spl.htmMy Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics
