Volume Levels for Surround Sound
bruticus
bruticus Posts: 10
Should the front be set higher than the rears?
Right now I have my front + center speaker set to +7db as well as my rears set to +7db.
Post edited by bruticus on
  • danger boy
    danger boy Posts: 15,722
    edited February 2008
    if you're hearing to much sound from your rear surrounds, it will sound akward. if your receiver had a auto speaker calibration. use it.. that will set the correct level for each speaker.
    PolkFest 2012, who's going>?
    +7 is alot,try leaving the 3 fronts to 0 and bump up the rears to +2 and see how that sounds to you.
  • jakelm
    jakelm Posts: 4,081
    Go buy an SPL meter from rat shack, and callibrate it correctly.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • engtaz
    engtaz Posts: 7,675
    jakelm wrote: »
    +1000 it is work the money to set it up right with a SPL meter.
    engtaz
    engtaz
  • bruticus
    bruticus Posts: 10
    is it better to turn up the master volume higher instead of having the db levels higher?
  • ben62670
    ben62670 Posts: 15,969
    bruticus wrote: »
    Yes. You should shoot for setting your mains at 0db. If after you purchase your SPL meter your rears are too high you can bump them a bit. If you have to bump them say +7db then you should cut your mains to about -3db, and raise your rears to +4db. Raising your DB settings can cause clipping at the line level stage be it a receiver, or a PrePro. When it clips at the line level stage the clipped signal will be amplified. Every Receiver/PrePro is different, but general rule is don't bump it more than +4db.
    BTW welcome to Club Polk
    Ben
    Ben
  • ward91
    ward91 Posts: 338
    just remember, its always better to "cut" than to "gain".
    (usualy)
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • 66chevyIISS
    66chevyIISS Posts: 857
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
