HDMI/Optical sound quality?
Tim2121
HI
I plan to purchase a HD-DVD player in a few days. My receiver doesn't have HDMI. Is there a huge different in sound quality between using HDMI and optical cable for audio connection? Thanks
Post edited by Tim2121 on
Yes there is. You can't get Dolby True HD or DTS A over optical or digital coax. You can only get it Via Hdmi. Now if your player has built in decoders and your receiver/preamp has a 6 channel in, you can use that to get the new audio formats. It sucks to do so with all that wire but it will get the job done.
The best thing to do if you want the best possible sound is upgrading the receiver/preamp to one that has HDMI and 1.3a with built in decoders.This way no matter which player you own, you will have the ability to process the audio one way or another.
DanDan
I could be wrong but I think that optical is a way better soundHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100 -
Dan
see I was wrong oh well learningHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
Dan
HAHAHA, but at least you have the right attitude about it ! -
hey I'm only in the 80 post range but do a lot of ready learning as I go alongHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
The thing is, when you start out with a relatively low end set-up, optical, analog, coax etc, don't sound so different. Optical may even have a slight edge over analog with all the noise affecting it.. But as you get up the food chain with more powerful/cleaner systems, analog will start to shine and digitals start to come off a bit lean.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek
