Anthem D2
hockeyboy
hockeyboy Posts: 1,428
edited February 2008 in Electronics
I couldn't find a thread reviewing the Anthem D2, and if my bonus is good I might be considering an upgrade. Can anyone tell me their likes and dis-likes of this expensive pre?
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus
(Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
Post edited by hockeyboy on
  • Ferres
    Ferres Posts: 310
    Heres a review link for the D2;
    http://www.hometheaterhifi.com/volume_13_3/anthem-statement-d2-8-2006-page1.html
    Some would recommend the Integra DTC 9.8 instead. Performance is close to the D2 for far less. With the money you save you can then add a dedicated Stereo pre for music.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • hockeyboy
    In researching this, I just don't see that much bang for my buck compared to my Marantz SR8001. If I have a Blu-Ray player that is 1.3 compliant and my Marantz is 1.1 compliant it doesn't look like I get a huge value in changing to either.
    Am I missing something?
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • Ferres
    Ferres Posts: 310
    It will depend on the stuff you connect with the pre-pro. Power amp, interconnects, cables etc.
    If you're not going hi-def yet, you should stay with your SR8001 :)
  • mantis
    mantis Posts: 17,637
    Ferres wrote: »
    Thats an intresting statement. The price difference alone is extreme. Anthem Statement can be compared to Krell, McIntosh , Lexicon etc and the Integra is a Japanese new preamp that has all the nessary processing for todays new audio formats. It's not much better then there receiver line. Actually it's not even in the same league.
    But I get why one would say go for that preamp. I'm in that boat right now. I plan on testing the **** out of the Integra(try to leave my past experience with there products at the door). There is nothing else on the market today yet that has it's abilities. The next few months should be fun.
    Dan
    Dan
  • cheddar
    cheddar Posts: 2,390
    I think one of the most interesting things is the point about being able to buy the 9.8 and a quality stereo pre for the cost savings. Kind of the best of both worlds giving a new meaning to the argument for separates...;)
  • venomclan
    venomclan Posts: 2,467
    I would think it really depends on what the D2 would be essentially used for - HT, 2 channel, etc...
    So far the 9.8 seems to be weak in the 2 channel arena. The D2 is a nice piece, but it better be at $6800.00. You can get a great performing pre/pro for HT and 2 channel for far less.
    Venom
  • mantis
    venomclan wrote: »
    Venom
    I so agree with you.
    Dan
  • Ferres
    Ferres Posts: 310
    Most of the complaints with the 9.8 is related to 2 channel. That's why I would recommend a dedicated 2 channel pre. :)
    You could also take a different none digital processing path. Get 3 descent stereo pre-amps for pure analog, will work as long as the player can do all the audio codec processing. You will lose a lot of control as well as video processing but you'll get less of that digital sound some dislike. :)
  • wingnut4772
    wingnut4772 Posts: 7,519
    I used to have one. It was awesome.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
