Spend 2K on your rig.
  • danger boy
    danger boy Posts: 15,722
    edited February 2008
    I'd use that 2K for a great sounding 2ch pre amp. which one, i don't know.
    PolkFest 2012, who's going>?
  • pearsall001
    pearsall001 Posts: 5,239
    TroyD wrote: »
    Let's just say that you had a windfall of 2K and you were going to spend it on your rig.....how would you spend it.
    Me?
    I'd probably sell my VPI HW-19 MkIV table (any takers? ;)) and move in to a Scout Master and a step up transformer.
    At this point, I'm feeling Conrad Johnson naked. I'd like a Premier 10 pre and possibly a premier 11A or premier 12 monos. Just to HAVE. Not that they would 'replace' my Melos/Heaths but just to have.
    BDT
    You know you want my CJ PV14!!! You've been drooling way to long. It's waiting for you in the flea market. It's got your name written all over it!!! Come & get it! :D
  • TroyD
    TroyD Posts: 13,124
    You know, I've thought and thought about that however, I REALLY am lusting after a Premier 10.
    BDT
  • I-SIG
    I-SIG Posts: 2,243
    I'd go for a Cary Cinema 5 to bi-amp my SRS's with. I'd have to throw in a little of my own cash to get one used.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • pearsall001
    TroyD wrote: »
    BDT
    At my Polkie price, you could enjoy it in your system until you snag a Premier 10. The CJ will fetch more than what you paid for it. Food for thought.
  • mulveling
    mulveling Posts: 505
    I'm looking to add a Martin Logan Depth sub, for movies and for experiment with 2ch. That's $1K used. I'd also like a Panny 42" plasma so I can free up some space used by my huge 34" HD CRT - that's at least another $1K for the non-1080p version. Then perhaps I can put my Tannoy TDC center (a beautiful but unwieldy 80lbs, with three 8" drivers) on the stand the old TV was on.
    I'm totally happy with my turntable, headphones, and tube preamps/headphone amps. Pretty happy with my tube amp & speaks. Lost interest in cables/power conditioning/tube rolling/tweaks (that crap was nickel and dime-ing me to death), so no immediate upgrade interests there.
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • jmwest1970
    jmwest1970 Posts: 846
    I'm already in the works for new speakers for the 2 channel, so I'd want to add a Cambridge Audio 840C and replace my ICs, PCs, and SCs as well.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    TroyD wrote: »
    Faak, man. I could double that and spend it without even blinking.
    You and me both! Okay, if I can't have the 22K Revel Salon2's, I'd just spend the 2K on media.
  • janmike
    janmike Posts: 6,146
    I would add it to the amount I need for my future ARC gear.
    Michael ;)
    NORTH of 60°
  • cmy330go
    cmy330go Posts: 2,341
    I'd probably spend half on a cartridge upgrade. Something that would come closer to using the full potential of my phono pre.
    With the other half I would probably snag a set of Von Schweikert VR-1's just to try them out.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Face
    Face Posts: 14,340
    I'd look for a pair of used Tannoy D900's or DMT15's and hot rod the crossovers.
    Or spend $1200 on the room and $800 on the new Pure AV UPS I've been eying.
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    Probably shoot for a Aqvox 2Ci MKII phono pre ($1400) then start saving for the next TT.
  • jazzisnumberone
    jazzisnumberone Posts: 53
    Maybe the Emotiva amp and pre-amp. Can do that for under 2K. It looks really sweet too.
  • ohskigod
    ohskigod Posts: 6,505
    I honesty dont know what I would do with 2 grand, I dig my 2 channel so much right now. maybe get a pre that can have as much detail as my passive TVC Promitheus, but with a little more gain.
    I'd like to try a Melos pre (like Troy has) sometime down the road, I liked that thing at Polkfest
    if I put it in the theater, I would probably put it toward a earthquake cinenova amp, just so I dont have so many amps in the system (save room) and keep the LSi's seriously powered to my liking
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • skipf
    skipf Posts: 694
    A Linn Sondek with all the upgrades.
  • del44
    del44 Posts: 686
    Man, I really need a turntable. Maybe a nice VPI.
