Which Bluray player?
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited February 2008
    Rike255 wrote: »
    If your receiver isn't HDMI v1.3 are you even able to pass audio through HDMI? Unless yours is 1.2 or better (which it could be) I don't think you can do it, you'll be limited to optical for audio. In which case the best you can hope for is PCM 2.0 or Dolby Digital and alike.
    No need to if the player is capable of decoding the various formats which then lets me send HDMI where I want ... Direct to the screen with nothing in between.
  • cheddar
    cheddar Posts: 2,390
    It is my understanding that the major audio differences between 1.0 and the next two steps 1.1 and 1.2 is the ability to pass DVD-A and SACD. Since internally decoded hi-def audio is converted to PCM, there shouldn't be any problem passing it to 1.1 and above HDMI to a receiver/pre. One of the main advantages to HDMI over the DVI spec was the bundling of audio in one cable. So if you have HDMI, you're pretty much good to go with almost all the versions unless you want to bitstream TrueHD or DTS-HD MA.
  • tecmo04
    tecmo04 Posts: 421
    When using the 5.1 preouts on the s301 and not the optical is it better to select true hd or pcm5.1 uncompressed?
  • Rike255
    Rike255 Posts: 131
    The S300 can't decode TrueHD nor can it bitstream it so that's a no in any case. Go with PCM for sure.
    Even if it could and you were getting all you can from the PCM track then, in theory, it should be identical to the TrueHD track (being that it's a lossless codec) anyways so it would really not matter.
    Polk Audio RTi8 Fronts
    Polk Audio CSi A6 Center
    Polk Audio RTi A3 Surrounds
    Polk Audio PSW505 Subwoofer
    Onkyo TX-SR805
    Sony Bravia V5100 46"
    Sony Playstation 3 160GB
    Sony Playstation 3 120GB Slim
  • tecmo04
    tecmo04 Posts: 421
    When listening to cd's through the 301 its only 2.0 Is it possible to have 2.1 using the 5.1 outputs?
