Anyone leave their amps on all the time
edossin4
I have an Adcom gfa 545 and a 555. I don't want to power them both through the one switched outlet on my Onkyo 805. And of course I'm to lazy to walk to the system every time to switch on 2 amps. Any ideas.
Onkyo Tx sr805
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Panasonic 54" rear projection
Direct HDTV DVR
PS3
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Direct HDTV DVR
PS3
Post edited by edossin4 on
I leave mine on all the time.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Yep, all of 'em. (cept for tube gear)
I leave all my rig on all the time (unless there's thunderstorms...just in case)._________________________________________________
my two Marantz Ma700s are on all the time. The outlaw mono has that detection sensor. or what ever they call it.
Use of a power conditioner with one device attached on delay would work, but switching both of those amps at once will create a heck of a current draw. I have to power my setup in a certain order: 7 channel amp on, then activate the receiver via a Belkin PF 60, which has a delay to the 2 channel amp. Watching the current numbers of the PF 60, this kept the draw down the best at system start up.
I see no reason you could not leave them on all the time, but make sure you have some measure of high quality surge protection. Most commercial power is very inconsistent and flexes high and low voltage spikes, and drops. Are you using a 15 amp or twenty amp breaker. If you were using a 20 amp circuit, clearly you would have more latitude.[ -
Nope,shut mine off.Who knows what goes on when I'm not home.Dogs might run behind there and yank out an I/C and short out the amp or something else.HT SYSTEM-
lsi 9's -
Same here. Who knows what could happen (lightning strike, short, blown amp, etc.) when the amp is powered on when nobody is around?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
My SS amps or designed to be always left on. The tube pre is turned off.
Mine are always off when not in use. They may not draw much current, but I still turn them off.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Only if my furnace is broke.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Nope.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
If they stay cool and don't draw much yes. Anything class D I leave on, all my A or A/B amps are off.
yes, all on all the time. My home is too busy to keep turning off and on. Now if I leave for vac, I turn everything off. But normally I leave everything on.
Everything stay nice and cozey and warm. Becides saving the life of the power switched.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Class D on, my Outlaws stay on, but they go into a standby mode without active signal.Shoot the jumper.....................BALLIN.............!!!!!
I leave the entire rig on 24/7. Thunderstorms are an exception, in which case I unplug and set the plug far away from the outlet.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Mine is in standby mode. When I had my Parasound, I left it on all the time except for thunderstorms.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Cathy,everything about you is in "standby mode".:pHT SYSTEM-
lsi 9's -
My Sunfire has auto-detect so powers on when a signal is sent. I leave my HK amp on all the time but it's only 100WPC.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
I leave both of my amps on all the time. I'm not sure how much power it uses, but I believe it's probably minimal.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
You can use a 110 volt AC relay on the switched outlet to increase its power handling. The relay is worht about $ 10 and might require a $ 5 socket to wire without soldering.
I'll leave my equipment on if I go grocery shopping. Once my day is over, I shut everthing down. -
I always turn everything off (Unless it has a standby feature like my TV and PS3). We get frequent storms over here so I wouldn't want something to happen while I'm gone.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
On All the time. If you shut them off, and get a good lightning strike it will hit your gound, and nutral which are not on the switch;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
And just what are you implying Tony? HUH, HUH, HUH???:p;):D
And Ben, "and nutral which are not on the switch." WHAT is nutral?Cathy,everything about you is in "standby mode".:pMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
There are 3 prongs on a standard wall jack. One is hot, one is neutral, and one is ground. Only the hot is normally disconnected from nearly any appliance. The neutral is basically a ground, or return. The only safe thing to do during bad weather is unplug your equipment.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You can't power either of them off the switched outlet, they draw too much current. The outlet is rated 1A max. -
Please consider using a relay. You'll need electrical experience on the level of wiring a switch and outlet.
Thank you William, that was my first thought when I read the original post. Hopefully he has not plugged them into the back of the AVR.
My amp has a 12v trigger from the AVR to turn it on. I don't want to leave it on all the time.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
Turn mine off at the end of the night. Krell recommends to "NOT" leave them on 24/7. I'll take their word for it.
Oh ok, thanks.There are 3 prongs on a standard wall jack. One is hot, one is neutral, and one is ground. Only the hot is normally disconnected from nearly any appliance. The neutral is basically a ground, or return. The only safe thing to do during bad weather is unplug your equipment.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
