DACs around $500
    tonyb Posts: 33,072
    edited February 2008
    No substitute for good quality gear be it old or new.Some older dacs out there are pretty damn good still.Like a MF tri-vista dac.Everyone drools over chip sets being used,but it's not just that as design and other parts used play into the end result.Some of todays cdp's have great dacs built in and you can find a few threads on members who upgraded their cdp's and sold their outboard dacs.Quality is key,don't throw 5 Franklins into a so-so dac when you can most likely get the same result by buying a quality cdp.Not dissin' outboard dacs,but don't see a reason to buy cheap ones.Computer rigs is a whole 'nother story.Just my .02
    heiney9 Posts: 25,447
    steveinaz wrote: »
    Well, oddly it takes some time. Lemme splain...
    I was bored one week, so I decided to just let the CEC run on it's own. I hadn't done this since buying the DAC1, so it had been about 2 years. At first I thought the CEC sounded pretty damn good (and it did)--but after about a week, I was ready put the Benchmark back in. Lost was the punch/slam, dynamics. The soundstage was smaller and not nearly as deep. Cymbals didn't quite have that "wood on brass" sound. There was less seperating space/air between musicians.
    I use the word "subtle" in the context of, you're not gonna be immediately impressed---but, after taking some time and listening to a large sample of your music, then the real differences come to light--in a more than subtle way.
    Make sense?
    I hesitate to be too excited about recommending external DAC's because most people who have never heard one usually expect this big "POOF" to happen, and their music will be instantly transformed. DAC's take listening time to really appreciate everything they bring to the table.
    Well said Steve.
    I have had at my disposal a friends Lite Audio DAC60 dual 24bit dac. It's a tubed unit. Very solid build quality, modded from Pacific Valve. A really nice looking and feeling piece. I just can't get into it. It sounds flat and lifeless compared to my Adcom and it just doesn't have the extension, detail and layering I'm used to. I have been demoing it in my system for a couple weeks and it's just different and not nec what I like as far as sound. It certainly isn't awful, just certain subtle things are different.
    I'm not sure if it's the tube output or the dac chip set used or a combination of both. One of the nicest sounding dac's are manufactured by Monarchy Audio and they still use the Burr Brown PCM-63PK chipset and those, while updated, are atleast a 10 year old D/A chipset. So newer is not always better depending on how the circuit is implemented.
    Also for me as a rule I dislike the sound of the 1bit "bitstreaming" type D/A chip known as delta-sigma loop processing.
  • Gaara
    Gaara Posts: 2,415
    tonyb wrote: »
    Very good point. I have used a variety of DACs using the same chips yet each had a different sound. Its all in implementation.
    P.S. My experience with the Paradisea is one with upgraded tube and opamp.
  • steveinaz
    steveinaz Posts: 19,545
    tonyb wrote: »
    Exactly. The most important--and most forgotten--final analog output stage.
  • halo
    halo Posts: 5,616
    for your stated budget you might consider:
    MSB Link DAC III ($249) and have it modified by ModWright (Level I $250).
  • adam2434
    adam2434 Posts: 995
    halo wrote: »
    Yeah, I mentioned the factory-upgraded MSB Link III (Nelson) in my original post. Then, down the road I could get the upgraded power supply.
    This is a tough decision. Now that I've had a taste of the NOS sound, I'm wary to go back to over or upsampling.
    If the MHDT dacs were more readily available, I'd probably be leaning in that direction.
    So right now the primary contenders are
    1) Mod my DAC-ah to fix the clipping and improve the sound (thinking about the asi-tek.com com mod, which is the same as the RAM mod).
    2) A new MSB Nelson Link
    3) Something used that strikes my fancy
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
    Russ has a stellar unit in the FM right now. Monarchy 18B
    http://www.polkaudio.com/forums/showthread.php?t=63377
    For a DAC around $500 that would be my number one choice. Excellent sounding piece, extremely well built with lots of attention to detail and design, especially in the analog output section.
    Nothing else in this thread really measures up except the Benchmark and you won't find one of those used for $500.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    eff you, my parasound can crush those other pieces...............
    put em up...............
  • halo
    halo Posts: 5,616
    heiney9 wrote: »
    Have you heard an MSB? Just wondering is all :)
  • halo
    halo Posts: 5,616
    adam2434 wrote: »
    adam - the MSB Nelson and the MSB modified by ModWright are two different things. ModWright also offers a level II mod for the MSB Link DAC III @ $375.
  • reeltrouble1
    I think H9 is just pointing out Russ has a nice DAC for sale, he gets I am kidding. There are many fine quality DAC's out there for Adam to consider.
    RT1
  • adam2434
    adam2434 Posts: 995
    halo wrote: »
    Yep, thanks, I just meant that I was looking at MSB DACs in general.
    I've read about those mods and do wonder how they would stack up against the Nelson, which can purchased for $500 new, which is about the same cost as the Link III with the Level I mods.
    RT1
    Bingo. ;) Plus I've had a lot of experience with some Monarchy gear, BTW, it doesn't need to be modded to sound great.............it comes that way :D:p
    I'll also add MSB has a great reputation. I looked long and hard awhile ago for a decent DAC and the Monarchy was always at the top. They don't come up FS too often. I had 2 deals fall thru on 18B's back then and I got a killer deal on my Adcom so that's what I went with, plus I needed (2) coax inputs.
    I was originally buying a dac for DVDp because it sounded so poor. I ended up using it for both my Nak cdp and my DVDp and have never looked back.
  • halo
    halo Posts: 5,616
    Thanks for the input Brock. There are a lot of DACs out there (as Ted pointed out). Sometimes its just a little overwhelming. Just my $.02. YMMV :)
  • Music Joe
    Music Joe Posts: 459
    I just spied a Channel Island VD-A2 on the 'gon for 400. You could get the upgrade VAC power supply later.
  • Yashu
    Yashu Posts: 772
    Oddly enough, NOS dacs benefit the most from monarchy DIPs due to the way the data points are converted, very sensitive to jitter. I have a monarchy DIP classic backing up my MHDT. I can hook any source I want and get the same liquid sound... it's nice.
    I would look into the monarchy 24/96 DIP if you really want another NOS DAC... I wish I had 24/96 support, but the classic is 44.1khz only, not that it's bad. Redbook done right sounds oh so nice.
    I am so impressed with the quality of the DIP, I often wonder what a monarchy DAC would be like.
  • halo
    halo Posts: 5,616
    MSB DAC III with PB1000 power base: link $500 obo
    Yashu wrote: »
    The DIP is a great piece and believe it, Monarchy makes a great DAC. I have always been impressed with Monarchy because it adheres to my philosophy of KISS. No frills, high quality parts, solid design. The music/analog comes first. No, BS approach.
    I just hope the earth doesn't split in half now that I have agreed with Yashu on something.
  • adam2434
    adam2434 Posts: 995
    Well, I decided on a new MSB Nelson Link DAC III - ordered one tonight. They're closing them out for $500, which is about 1/2 of the original MSRP. Figured I give something else a try and wanted to buy new this time (although the DAC design goes back to 2000). At that price, it's like getting an unused piece at a used price.
    I like the idea that it reclocks the bitstream, given that I'm using my PC as a source (in addition to my Sony), and PC SPDIF is known to be jitter-prone.
    Of course, I'll lose the nos sound, but what the heck, time to try something new.
    Down the road I'd like to pick up the P1000 power supply upgrade or the power supply upgrade from Monolithic Sound.
    Thanks to all for the input. I'll report back once I break it in.
    Data sheet is attached for those interested.
  • rskarvan
    rskarvan Posts: 2,374
    Yashu wrote: »
    Thats odd... I have the Monarchy 24/96 DIP and I wish I had a classic 44.1 Khz.
    My 24/96 Dip works flawlessly.... I just was curious what the master clock would provide in the DIP Classic.
  • Yashu
    Yashu Posts: 772
    Well... I have not compared them, but for 16bit redbook, I can't imagine it getting much better (for the price). I only wish I could play with some higher bitrates. I think that is the only reason for wanting to try the 24/96.
    From what I understand, the classic can be upgraded to 24/96 support with a little something, it may just be as simple as a jumper.
  • adam2434
    adam2434 Posts: 995
    Got the MSB Nelson Link today.
    Here are my initial impressions.
    Build/Appearance:
    Solidly built and surprisingly hefty for something with an outboard power supply. It won't win any beauty contests with its plain-Jane, dark grey matte finish though. The led's are also very bright.
    Sound:
    I should not be listening until it breaks in a bit, but could not help but give a listen right out of the box.
    Wow is the 1st word that comes to mind. The solidness and depth of the bass is the 1st thing that struck me, literally. The DAC-ah has prodigious bass, but lacks definition compared to the MSB.
    The other words that come to mind are timber and timing. It sounds balanced from top to bottom, with no part of the spectrum calling undue attention. The sound is much more detailed than the DAC-ah, but is not bright or harsh at all. It also has very good timing and attack, which gives music nice snap and drive - toe tapping appeal.
    I had upsampling engaged the whole time.
    I need to give it a few days to break in, but I'm impressed so far.
    I also have the P1000 power supply upgrade coming (new from a member here). It has a torroidal, filter caps, rectifiers, etc. and takes place of the large wall wart that comes stock. As good as it's sounding without break-in and with the wall wart, I can't wait to get it broken in and get the P1000 connected.
    Need to get back to listening - Buddy Guy's Blues Singer is cued up.
    Edit: the stock power supply is not a wall wart; it's more like a laptop PC power supply.
  • adam2434
    adam2434 Posts: 995
    Meant to post a pic (albeit crappy)
  • AndyGwis
    AndyGwis Posts: 3,655
    congrats on your score!
    If anyone else is looking for one of these, here's on (zero feedback seller, though) for what seems to be a good price. Upgraded with power supply and such.
    http://cls.audiogon.com/cgi-bin/cls.pl?dgtlconv&1207630476
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • adam2434
    adam2434 Posts: 995
    That is a pretty good price.
    I'll have about $750 in my new units.
  • mulveling
    mulveling Posts: 505
    AndyGwis wrote: »
    Here's a what looks to another good deal, just posted, in case somebody's ready to pounce on it:
    http://cls.audiogon.com/cgi-bin/cls.pl?dgtlconv&1208223789
    MSB Nelson DAC, P1000 power base, AND Monarchy DIP24/96 with AES digital cable all for $795 from a seller with tons of feedback.
    Edit: on second though, the first deal is still better since the DIP is only $200 new (on a side note Monarchy's website plays annoying music. I hate it when websites do that).
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • AndyGwis
    touche, Mul, touche!
