Subwoofer in Direct/Stereo mode?
Serendipity
Like most AVR's, my Onkyo TX-SR702 does not output any signals to the subwoofer when in 2-channel "Direct" mode. I was thinking about using the speaker-level connections to get around this, but thought that I would ask here first:
1. When using the speaker-level connections, does the crossover in the sub act as a low-pass filter only, or does it also cut the bass to the front speakers?
2. If the sub's dial is set to 80Hz, the front speakers don't play full range and only go down to roughly 80Hz? Or does the setting only affect the sub?
3. Are there any drawbacks to using this setup?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
I think it depends a bit on the sub, but my understanding is that generally the sub has a low-pass filter only and a full signal is sent to the speakers.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
if you put it in stereo it will work with your 2 frontsHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100 -
Do you have a external amp for your fronts?
If you, you can run 2 Y's, one to your sub, one to your amp.
If you don't, you can run the front pre amps L&R to the sub in L&R, NOT LFE in. Then you'll have to tune your crossover frequency. Your mains should still play full range."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
AVR to sub, then sub to speakers:
Sub xover for sub, full range for speakers. The sub does not contain a xover for the speakers hooked to it. The xover only works for the sub itself.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
No, I used to have an Adcom amp but I gave it away to a friend.
So I guess the only thing I can do is to run the speaker wire connectors into the sub and then that out to the speakers, that way I don't have to worry about any L&R line in jacks or LFE connections, right?polkaudio RT35 Bookshelves
This is what I'm talking about:
(From www.crutchfieldadvisor.com)
"Q: Can I hook up a powered subwoofer if my receiver doesn't have a subwoofer output?
A: Absolutely. Most powered subwoofers have speaker-level connections for use with virtually any receiver. Just run one set of speaker cables from your receiver's main left and right speaker outputs to the subwoofer, then another from the subwoofer to your main left and right speakers (you'll need an extra pair of speaker cables)."polkaudio RT35 Bookshelves
Yes. Most all subs have high input spearker terminals. These terminals are used to hook speaker cable to them from the AVR's speaker out put. Low input are the RCA input, used to hook the sub up via RCA jacks.
After hooking up the high input on the sub you hook the speakers up to:
1. Either directly to the AVR via speaker out.
2. The sub speaker out on the sub.
In either connection, the AVR should be set to Large mains. Having full range going to both sub and speakers. The sub xover should be set, by ear, where it blends in with the main speakers. There is nothing to do with the main speakers. Excpt calibrate them with the channel level, on the AVR to blend with the rest of the HT.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
When you say hook the speakers "to the AVR via speaker out," do you mean in parallel with the sub that's also connected to the AVR via speaker out?polkaudio RT35 Bookshelves
Yes.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Okay, thanks!polkaudio RT35 Bookshelves
I have done this. Because I am using dual subs and the subs were too far to run cable form them to my speakers.
But I changed since then, LFE for subs now.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Oh, okay. My sub will be placed right next to the main speakers, so I think I'll do something like this:
Receiver (speaker terminals) -> Sub -> Speakerspolkaudio RT35 Bookshelves
Did you notice any differences in sound quality when you made this change?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Absolutly. The 7's were full range before with the subs, in direct mode. By connecting the subs to the LFE I am able to adjust the xover point on the 7's to 60hz. IMO, better for HT, for music it isnt bad. I can just switch the AVR to large + sub for mains.
But direct mode kills sub, when sub hooked to LFE. So I rarely play direct mode. In the position my 7's are in bass responce is not so good. But listening to HT in such high dB's, I set my xover to 60hz as not to blow the 7's and allow the sub to carry the explosions...Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Would just like to point out -
If you have your mains set as "Large" and the receiver is set in any 2-channel mode, then the sub does not receive any signal. So that is the motivation for me to try the speaker level connections
I'd have to set the mains to "Small" or hook up the sub the way jakelm mentioned to get it working while listening to music.polkaudio RT35 Bookshelves
HMMMmm...You AVR does not have Large + Sub stereo? For 2 channel listening?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I'm away from my AVR right now (I'm in my college dorm) so I couldn't really tell you until I go home and look at it.
From what I recall though, if the mains are set to "Large" the sub does not play in stereo mode. When set to "Small," the sub plays in stereo mode.polkaudio RT35 Bookshelves
Check again, but the 702 should have Large + Sub.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
You're probably right.
I don't think it's enabled by default though, because out of the box the 702 does not output anything to the sub in Stereo mode.polkaudio RT35 Bookshelves
I am reviewing the manual right now.. Give me a sec.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Page 46 of the manual. Manual speaker setup. Check to make sure that the sub is yes and the front mains are large. That should be the default setting, if it isnt, maybe by changing this opetion , it will make it default.
Press reciever then setup, go to option2 speaker setup., then option one, speaker config. There it should give you the option to adjust speaker size and subMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
A while back I made sure the sub was set to "yes" and the front mains were set to "large." In this configuration the subwoofer only played the .1 of a 5.1 DVD audio track. It did not play on music.polkaudio RT35 Bookshelves
After hitting stereo on the reciever, did you try hitting stereo multiple times to get different stereo modes? Or while in stereo mode, go to the speaker config option to make sureMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I think I did that. IIRC, the only time the sub was active was in a surround mode, such as DPLII, Neo:6 or DD/DTS.
I just read the following: http://www.crutchfield.com/App/Product/Item/Main.aspx?g=10420&i=580TXS805S&tp=179&tab=detailed_info
For the TX-SR805, it states that there is a Double Bass function: "You can increase the bass output by activating the Double Bass function. This function feeds both the LFE and left and right channel bass output to the subwoofer. Double Bass can be set only when the subwoofer is set to On and the front speakers are set to Large."
Is that what I should be looking for?polkaudio RT35 Bookshelves
It says it in the second photo.. That in stereo mode front and subs will play.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Yes, double bass = front bass and sub bass
Double bass is default off. Change to on. There ya go
My dad has the same AVR, I remember strereo working just fine. Now I rememeber (or you remembered) double bass.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Hmm, interesting. The manual is correct only if you have "Small" mains selected... or am I doing something wrong?
I think I'll go and look for a "Double Bass" setting. Maybe it should be set to on.polkaudio RT35 Bookshelves
Aha, now I understand this whole thing. Double bass needs to be on.polkaudio RT35 Bookshelves
I edited my last post, sorry, It is the double bass feature.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
