adding a power amp to receiver
jake_angel
jake_angel Posts: 9
how do i go about hooking up a separate power amp to my receiver that does have pre outs ?
my system is : receiver = Carver c-1000a
power amp = Carver M-1.5t
main speakers = RTI 150's
center = CSI 140
sub = PSB subsonic 5
the reason for adding the amp is the rti 150's need the power that the receiver cant dish out without getting very hot + shutting down
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2003
    1. Run a pair of interconnects from the main pre-outs (front L,R) to the 1.5.
    2. Disconnect the main speakers from the 1000.
    3. Connect the main speakers to the 1.5, done.
    Cheers,
    Russ
  • jake_angel
    jake_angel Posts: 9
    edited March 2003
    i forgot to ask do i need a pre amp for the Carver M-1.5t ?
  • RuSsMaN
    edited March 2003
    No, if the 1000 has pre-outs, it IS your preamp.
    Cheers,
    Russ
  • jake_angel
    jake_angel Posts: 9
    edited March 2003
    thanks russman i didn't think so thanks for your help .....
