2 channel; 3 amps 6 channels 2250watts
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2008
    There's not many on this board understand transistor bias when it comes to A A/B or B, and you wish them to post back on a 1 volt offset issue. ;)
    You're in your own league :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited January 2008
    Some how I have this vision of Ben,looking like Doc from Back to the future.
  • Systems
    Systems Posts: 14,872
    edited January 2008
    Congrats on getting it working.Does that amp have a pot for nulling offset?1 volt offset is high , are the + and - DC voltages feeding the input stage fairly close.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited January 2008
    tonyb wrote: »
    Some how I don't think you're too far off ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    GV#27 wrote: »
    Should have a pot for each channel, right?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    ben62670 wrote: »
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
    No smoke!!! None!!! I have output!!! all systems go!!!
    Damnit, I should have quoted the excitement from last night...:p:p
    Congrats Ben, way out of my league.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    edited January 2008
    jakelm wrote: »
    Yes if it has adjustments for offset then it will have one for each ch .Some amps don't have them relying instead strictly on component matching and allowing some offset(50mv or so) to exist.
    Testing
    Testing
    Testing
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    The problem is the inputs are receiving some sort of dc feedback from somewhere in the system, and amplifying it to 1vdc on the speaker outputs. The output from an amp is AC only. DC output kills speakers. There is no adjustment for DC out(self biasing). I am going to try to locate where the DC is leaking into the input stage. I can't DC couple the inputs, because there is DC present even with no source hooked up.
    Ben
  • Systems
    edited January 2008
    ben62670 wrote: »
    Are the + and -DC voltages feeding the input stage close to being the same.?If one is lower than the other this could be the source of the offset.
    Yep if you feed them enough,been there done that,a wiring error in one of my projects sent 40 or so volts of DC to a 6.5" woofer and destroyed it in seconds.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2008
    GV#27 wrote: »
    Are the + and -DC voltages feeding the input stage close to being the same.?Yep if you feed them enough,been there done that,a wiring error in one of my projects sent 40 or so volts of DC to a 6.5" woofer and destroyed it in seconds.
    The Adcom service manual doesn't tell ya much. Its funny you mention the dc for the input stages. When tracking the problem before I found something amiss with the power at the OP amp. The DC output is .2 watts at idle which make the cone jump just a hair. I ran it like that for a year, but I would like to get it right. I am listening to some Allison Krause on it right now driving some custom monitors, and it just sound so sweet. I am going to play a little, and enjoy before I let problem hunting annoy me. I am so pleased that I have this amp going. These are a special product in the Adcom line up;)
    Ben
  • ben62670
    edited January 2008
    Well I rewired my SDA's for one amp for now. I don't need 2000+ watts in my office. They are wired for 2.6ohms on the MM. I have driven them to 116db with this amp, and a pot as a pre today. Sounds good. The highs are too much though. They were controlled by another amp with less watts. I'll have to tame them a bit;)
    Another ugly pic:D
    DSCN0923.jpg?t=1201405714
    Ben
    edited January 2008
    Jeez Ben....when's the Death Star going to be fully operational?
  • ben62670
    edited January 2008
    HeHe I just reached 125db with Fleetwood Mac's worlds turning bass riff:D:D:D Nice and clean. The only problem is the bass made the CD skip:( Those transistors are getting better, and better. No more distortion lights flickering at high levels anymore! Whoo Hoo!!!
    Ben
  • disneyjoe7
    edited January 2008
    ben62670 wrote: »
    Dud you're just F'ng mad.
    BTW did you ever get juiced working for the "Electric Company" :eek:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    edited January 2008
    disneyjoe7 wrote: »
    Nope I never hit more than 1 wire at a time:D
    The scariest thing though was when I touched a wire with the tree, and the butt was in a wet swamp. Me drop saw and run:eek: Hair stood up, and it wasn't just cause I was scared:p
    My buddy took out the power in six towns once, and it happened to be just before Luke and Laura's wedding on that popular soap in the eighties:D
    Thousands of house wives wanted to kill him:D
    Ben
    edited January 2008
    125 db's Ben? I had such high hopes you could do better.:p;):)
    edited January 2008
    I use to be able to make a cd skip with the SRT's and 3000p's bringing up the **** end and I swear,drywall has cracked loose around nail heads in the ceiling from it.Those speaks you have there are awesome.Now,how you gonna get them to conyers?
  • ben62670
    edited January 2008
    tonyb wrote: »
    I know that is not just a story. I have done it. I can't believe this amp is just getting better, and better. I have a rat shack meter, and it goes to 126... well I just pegged it, and had a hair more. Slow response, A weighted. I have to stop now. I need my ears;)
    Ben
    edited January 2008
    You getting your db's at 1 meter or 3 ?
  • ben62670
    edited January 2008
    tonyb wrote: »
    If I am a 1 meter, or if I am at 2 between the two speakers I get about the same.
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited January 2008
    You sonosub looks pretty small now.
    engtaz
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Are those speacial subsonic boxes at the top of the towers?:p
    After a day of listening, is it sounding better? Starting to warm up?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited January 2008
    engtaz wrote: »
    engtaz
    It makes me feel so inadequate:o
    jakelm wrote: »
    Yes! Transistor burn in has a tremendous effect I gained much more power, and the high end smoothed out a lot! I am thinking of changing all the transistors, and caps in my GFA-5800 also!
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited January 2008
    Let us know what caps your changing and what differences it makes.
    Just want to say thank you to the mad scientist for the constant updates,
    engtaz
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Did the change effect the ohm stability?
    Is the temp the same?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited January 2008
    jakelm wrote: »
    Stability is sweet. It does get hot, but never goes into thermal shut down. The temps reach 150f, well within spec for longevity, and would run cooler if DC offset was corrected. I must include the new caps, and transistors helped a lot. I was get a beta of about 70 on the old chips, and this batch I am getting 80. Thats a nice little gain;) Add to that my distortion lights are never flickering:)
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Have you ever tested the efficiency of your towers?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
