How far away do you sit from your SDAs?
nms
nms Posts: 671
edited February 2008 in Vintage Speakers
OK, so I'm wondering how far away from my SDAs I should sit for ideal imaging. My speakers are approx 3.5 feet apart from the inside edges of the cabs (too close I know, but I can't do anything about it). From between the midrange drivers it's a little under 5 feet.
Should my ears be 3.5 feet away from the front plane of the speakers (which seems really close), or should I sit about 5 feet away?
Thanks.
My system
"The world is an ever evolving clusterf*ck." --treitz3
Post edited by nms on
  • avguytx
    avguytx Posts: 1,628
    edited January 2008
    My SRS II's are about 6 feet apart from inside edge to edge (7.5' center to center or so) and I sit about 12 feet away from them.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • John in MA
    John in MA Posts: 1,010
    edited January 2008
    I listen to 1.2TLs from about 6' away, but that's a result of my temporary situation until I can install them in a nice big room.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    My 1.2TLs are 6' 5 1/2" apart. With my head rested, my ears are about 8 1/2" away and I'm good but I notice that when I place my ears exactly 6' 5 1/2" away from dead center plain of the speakers it is pinpoint perfect!
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2008
    According to your placement you should sit 4.5 feet from your SDAs to complete the perfect triangle. My eyes would cross staring at mine that close.:D
    Mine are 7 feet apart and I sit around 8-9 feet back even though 7 feet sounds best.
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Mine are 6' apart and I sit about 8' away. Sounds great.
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    Mine are about 10 miles east of me in Doug's storage but I'll let you know when I get 'em.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Well mine are kinda big, and they are 7-9 feet apart, and are feed over a 1000wpc so it is best if I am about 9-11 feet away. Walk back and forth between the center of your speakers, and you will hear weird phase issues when too close. This is most noticeable when playing sine waves.
    7 feet apart here.
    Ben
  • zingo
    zingo Posts: 11,258
    edited January 2008
    I love that you listen to sine waves. But then again, who doesn't?!?
  • lightman1
    lightman1 Posts: 10,796
    edited January 2008
    ben62670 wrote: »
    7 feet apart here.
    F you Ben.;)
  • ben62670
    edited January 2008
    lightman1 wrote: »
    F you Ben.;)
    :D
    My neighbors are going to hate me:o
    Ben
  • ben62670
    edited January 2008
    Now you understand my amp post?
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited January 2008
    "F you Ben."
    LOL too funny
    engtaz
    engtaz
  • nms
    nms Posts: 671
    edited January 2008
    Thanks guys. I did some critical listening last night with my ears about 4'1" away from the speakers and the soundstage was noticeably improved over my previous position ~ 6' away. I'll try moving back a few more inches and see what happens.
    It's a little bit intimidating to be that close with the grills off, seeing a drivers jumping, and knowing with a quick flick of the wrist I'd hear nothing but ringing for the next few hours... :) But so far I haven't done that (and in all seriousness I keep the listening levels below hearing loss levels)
    My system
    heiney9 Posts: 25,430
    edited January 2008
    You need to generally sit in an equilateral triangle. I sit about 6 feet away so my SDA's are about 6 feet apart. This loose formula may not work at either extreme as well but generally with SDA's this works.
    One nice benefit of later generation SDA's is they seem to be much better off axis listening. Meaning even those outside the sweet spot still get a good dose of the SDA magic even though they aren't right exactly in the sweet spot. Earlier SDA's the sound stage collapses quite a bit when you move L or R of the sweet spot.
    EDIT: Also my couch sits up against the back wall of my listening room and this isn't ideal. I can sit forward on my couch and get a slightly better SDA experience. Not having a reflection srface directly behind where you are seated is optimum. Still where I sit I still get about 90-95% of the magic. ;)
  • Marty913
    Marty913 Posts: 760
    edited January 2008
    zingo wrote: »
    My setup is probably more like zingo, my 1C's are 9 feet apart and I'm 12ft away but still experimenting. I think for critical listening or dedicated 2-channel I would buy into the "perfect triangle" thing but I also think there are usually other mitigating factors (home theater & WAF are a couple). I agree with H9 that the older SDA's are a little more problematic. The soundstage on my 2's doesn't hold up nearly as well as the 1C's if I sit too far back.
    I would think Ben would have a decent soundstage in a drive-in movie theater. By the way, I've checked on Amazon and the download selection on sine waves is really pitiful. :rolleyes:
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • schwarcw
    schwarcw Posts: 7,358
    edited January 2008
    7 1/2 ft. apart, 9 feet back.
    I always wondered why you should use the edge of the speaker at the measure point, why not the middle? Either case, I don't think +/- a ft does not mean a whole lot. Room reflections (proximity to the walls), nulls, etc. will have more of an affect.
    Carl
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2008
    8 and a half inches away from speakers separated by 6 and half feet!?! :eek:
    You got a big damn head, Joe! :cool: No wonder you have "golden ears!"
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
    tonyb Posts: 33,069
    edited January 2008
    9 FT apart.....sit roughly 12 ft back.Room is roughly 24 by 24.
  • nms
    nms Posts: 671
    edited January 2008
    Get a big piece of soft foam and glue it to your wall. This will fix your reflection problems... but then again, this wouldn't pass the WAF test :)
    My system
  • BobMcG
    BobMcG Posts: 1,585
    edited January 2008
    Also a believer in an equilateral triangle, measuring speaks center to center and room to spare behind ears:
    Speaks 9ft center to center, ears 9ft from speaks centers & 4ft to wall behind ears.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2008
    BobMcG wrote: »
    Looks like a perfect arrangement...I wish I had that kinda space.
  • schwarcw
    edited January 2008
    BobMcG wrote: »
    Exactly! I don't like the inside edge to edge, doesn't mean too much. The middle seems to be the best reference point.
    Carl
  • ND13
    ND13 Posts: 7,601
    edited January 2008
    Mine are 8 ft apart and I sit 8 ft from them. The closest side wall is about 4 1/2 ft. They are also 8 inches from the back wall.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited January 2008
    Like ND13 I also sit eight feet away from center and my speakers are eight feet apart, center to center. They are eighteen inches from the back wall.
    Drew
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2008
    About 25-30 feet since they have been in boxes for almost 2 years. I'm told they sound phenomenal.
  • engtaz
    engtaz Posts: 7,669
    edited January 2008
    10' speaks are 8' apart. SDA SRS 3.1TL's
    engtaz
    engtaz
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2008
    12 feet apart, 13 foot away +or- 1ft measured with my ears not a tape measure.
    I Had them closer together but then they were to far from the outside walls and lost a little something.
  • BobMcG
    BobMcG Posts: 1,585
    edited January 2008
    Joe08867 wrote: »
    Too far from an outside wall? I wasn't aware that was a problem unto itself.
    Probably more often than not, being too close to an outside wall is a problem due to early side reflections that are created. In small rooms it's probably one of the more common problems people face. It's also one of those problems that's not always "fixable". They only have the space they have in which to work.
    I'm curious, how far from the outside walls were they before and how far now?
  • sda2mike
    sda2mike Posts: 3,131
    edited January 2008
    i read this thread and realized i sit 8.5 ft from my speakers and they're 6 ft apart...last night the wife went out long enough for me to have a session;). i spread the sda's to 8.5 ft apart and 8'' from the back wall...HOLY SHIITE!!:eek: what a difference!! took some getting used to at first actually! sda effect has gone through the roof! soundstage, ditto! placement of insruments and singers, intoxicating! there was one song, i forget which, but anyway they used 'chimes'. I could hear the actual placement - left to right- of the chimes. we're talking maybe a foot! i've never heard anything like it! after some random action on the cd's, i landed on steely dan's - the royal scam...my god!! i love these speakers! i'm hearing stuff for the 1st time here:)
  • hoosier21
    hoosier21 Posts: 4,415
    edited January 2008
    sda2mike wrote: »
    And you call yourself SDA2Mike :rolleyes:
    :D
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
