Amp hookup to a onkyo 805
Ok how do i go about hooking a amp to my 805?
Can i hook a 2 channel amp to the front preouts
and still run 2 speakers from the reg. speaker outs.
To have 4 speakers in 2 channel stereo.
jerry
Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
Basement-Audiosource pre/tuner,GFA-545,Onkyo
DX-1400 and RTI10s
Garage-GTP-450,onkyo M-282 and R50s with RTi55
drivers and X-overs.
My baby 18' V-king Mod VP with a merc 2.4 BP.
KTM 620 Supermoto
Post edited by hydrostream on
Welcome!
    edited January 2008
    jerry
    Yes. You can hook up just the fronts if you like.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    edited January 2008
    Better check your manual and maybe even check with Onkyo Customer Service.
    I have a Yamaha RX-V1800 and was thinking of doing the same thing, but the manual was explicit in NOT connecting up the pre outs AND the speaker outs at the same time.
    However, on the AVS Forum, someone else did this exact thing and the universe did not implode :p
    Do so at your own risk.
    Erik
    edited January 2008
    Good call Erik. I have done that before with one of my old Yamis and had no problem, but the manual might know best.
    edited January 2008
    I've done that with a HK and it wasn't a problem.
    edited January 2008
    The manual does not go into detail about adding
    amps.
    jerry
    DX-1400 and RTI10s
    KTM 620 Supermoto
    edited January 2008
    Erik Tracy wrote: »
    Erik
    I think it ment, not the same channels. But if you run the mains pre's, then just dont hook anything up to the AVR's mains speaker out. But using any AVR's pre/outs and using the AVR to drive the OTHER channels will never be a problem.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    edited January 2008
    jakelm wrote: »
    Agree - same channel hookups for the pre outs and speaker outs is what is not advised - at least for the Yamaha (pg 29 of the RX-V1800 owners manual).
    Other AVRs may be different.
    That it 'works' in other instances may indicate that the owner's manual is over conservative.
    Still - if someone were to run into an issue later with the unit, it may void any warranty.
    edited January 2008
    Someone told me to use the amp on the front preouts
    and run another set of speakers using the back surround
    channels.
    But how will that work in 2 channel mode.
    Looking to use both pairs of RTi8s in 2 channel
    audio.
    jerry
    DX-1400 and RTI10s
    KTM 620 Supermoto
    edited January 2008
    This afternoon a friend of a friend came over with
    a Adcom cfa545 to try on my 805.
    Hooked it up on the L&R front preouts.
    Played some cds in 2 channel stereo using
    a pair of RTi8s.
    It sure seems like the adcom has more power
    rated @ 100 wpc and the 805 claims 130 wpc.
    Sounded great (powerful).
    I'm not sure how the wifes going to react when
    i tell her i need to buy a amp.
    I was thinking of selling the 805 but maybe
    i will just add on.
    jerry
    DX-1400 and RTI10s
    KTM 620 Supermoto
    edited January 2008
    Erik Tracy wrote: »
    Don't think there is a receiver on the market today that lets you use pre outs and speaker connections on the same channel.Nobody does that for the obvious reason.When useing a pre out for any channel,the amp part of the receiver is dead to that channel.
    edited January 2008
    channels.
    audio.
    jerry
    Should be in your receivers set up menu.You should be able to set up the source,cd,and assign what speakers you want while in stereo.Now 2-channel direct is different,if you have that option.
    edited January 2008
    a pair of RTi8s.
    i will just add on.
    jerry
    there you go.. that's what you need
    PolkFest 2012, who's going>?
    edited January 2008
    a pair of RTi8s.
    i will just add on.
    jerry
    I'd keep the 805 and use it as a pre amp. It has a ton of bells and whistles. If you need more power you can bridge that receiver to run huge amounts of power to the front speakers. Only problem with that is that you can not use the surround channels.
    I am using my 805 to power my center and my surrounds. I am using an Adcom gfa 555 to drive my rti12's.
    Onkyo Tx sr805
    Oppo Dv-981hd
    Onkyo Dv cp704
    Adcom Gfa 555
    Adcom Gfa 545
    Polk Audio rti 12
    Polk Audio cs400i
    Polk Audio fx300i
    Panasonic 54" rear projection
    Direct HDTV DVR
    PS3
    edited January 2008
    "Huge amounts of power" and a receiver don't equate.
    edited January 2008
    Well i talked to onkyo tech help and they
    said no problem the preout are active at all
    times.
    jerry
    DX-1400 and RTI10s
    KTM 620 Supermoto
    edited January 2008
    :D ROTFLMAO!!!! So true!:D
    tonyb wrote: »
    edited January 2008
    What are your speakers? example:If your fronts are RTi10 and the other pair are bookshelves, you can probably run the 10's from the A channel preouts thru an amp, then the bookshelves on B channel. Then just leave it in stereo w/ both channels on.
Welcome!
Welcome!
