LSI15 First Impressions with AdCom 5503
Gizmo99
Gizmo99 Posts: 169
edited January 2008 in Speakers
So I finally hooked up my ADCOM 5503 to my Yamaha Rx-v1800 Preout.
Originally I had the speakers set up to the Yamaha only.
I didnt put up the volume too much (because its getting late) but honestly, I didnt notice a "night" and "day" difference I was expecting.
I played the same scene from the ratatouille movie (rat escaping) and while it did sound abit louder. I didnt too much of a difference.......
I will perform more testing in the day where I can turn it up...
Off topic: I notice when I set the bluray audio option to Dobly Digital. It sounded better than PCM. I though PCM was the best audio I can pick..
Receiver: Onkyo TX-SR805
Amp: Emotiva XPA-5
Front: LSI15
Center: LSIC
Sourround: FxiA4
Rear: Fxi3
Sub: Bic H100
TV: Sony 52' XBR4
"The more time you spend researching here, the less money you will have" :D
Post edited by Gizmo99 on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2008
    I think when you turn it up tomorrow you will get better results.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Also, you should try it with music and see what you get. Plus, the volume might help give you those better dynamics like wingnut was saying.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited January 2008
    I tried that exact same amp when I had my 15's. I used a Pioneer AVR as a preamp. I was not impressed.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • DeusExa
    DeusExa Posts: 491
    edited January 2008
    How are the Carver 1. somethings......
  • wingnut4772
    edited January 2008
    Mike
    Hmmmmm. I have never heard one...
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    I ignored the sleeping residents near me and turned up the volume to test the system.
    I defintely hear the difference. Sounds are more pronounced, I hear more details in the sound. Imaging is also better.
    What other amp would you guys recommend (200WPC)?
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
  • mantis
    mantis Posts: 17,321
    edited January 2008
    Basically adding an amp gives you more power. If you want night and day, you need a preamp of higher quality.
    When using a receiver as a preamp, you are still going to hear the sonic signature of that receiver. The amp will help when the needs exceed the abilities of the internal amps. This is why it sounds better louder with the external amp. It has alot more current and the ability to be alot more dynamic.
    Most receivers amps need all the power they have ust to drive a 4 ohm load speaker. Most receivers are not rated to drive 4 ohm loads. While most even not rated will do the job but have little or no dynamics.
    Seeing your using a Yamaha as a preamp, I suggest you look into B&K amps. they tend to have a warmer sonic signature. It's not easy to hear the difference from one power amp to another but there are details that change slighty.
    Dan
    Dan
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2008
    Make sure you recalibrate the system. And by all means listen to some music as well for further analysis.
  • wingnut4772
    edited January 2008
    Gizmo99 wrote: »
    See? Do not doubt the Great Wingnut!:p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    I take back my initial impression. I turned it up loud this morning and defintely hear the difference. The LSI15 were able to breath and produce clear and crisp sound.
    Going to do some more testing...
    I posted this on another thread but I can't figure out why Ratatouille on bluray plays so much nicer with DD 5.1 versus PCM.... I remember Casino Royale sounded so much better in PCM. Maybe I have something set up wrong
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
