Monitor 10B binding post
NeilGabriel
My posts are about the size of match sticks with holes the size of needles. Can these be replaced with larger posts such as the 5s have, or with 5 ways, without a major tear apart job? Thanks.
apologies if this has been asked 29 times...
Post edited by NeilGabriel on
You'll have to look inside the box.
The post itself should be held to the mounting plate by thread and nut. Unscrew the nut from the inside of the box, drill a bigger hole if needed, and screw in the new ones.
You can get some posts by taking apart a new binding post 'plate'. If you have a breadboard anywhere in your closet, that might have some you can use.
edit: changed 'thread and bolt' for 'thread and nut' -
Yes. Easy.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks. Think I might just get some gator clips~
A piece of cake and a glass of milk!
Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
