Panasonic blu-ray
dholmes
The Pansonic blu-ray player, I think its the 10a model the one with 7.1 analog output is still available for around 450.00 is it worth it? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I'd go for the BD30 at around that same price.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Really depends if have an HDMI 1.3a receiver and want to bitstream the lossless codecs (Dolby TrueHD or DTS-MA) or if you want to send multichannel analog to your receiver. If you have a 1.3a receiver, then the BD30 is better because it can bitstream all of the formats and its a 1.1 profile player.
If you want to send analog multichannel out, then the bd10 is probably better because it can internally decode DTS-HD/TrueHD and has 7.1 analog outputs. -
Heck for the price, might as well get the ps/3.
Pros: already has HDMI 1.3, can internally decode audio or play them at bitstream
Cons: Bluetooth only remote
The Home Theater Setup:
Fronts: Polk RTi6
Center: Polk CSi5
Surrounds: Polk FXi3
Rears: Polk FXi3
Sub: Polk PSW125
AVR: Denon 3808CI
TV: Mitsubishi 65" Diamond DLP (WD-65833)
Game Console: Xbox360
Game Console/Blu-Ray: PS3
Satellite: DirecTV HD-DVR (HR21)
HD-DVD: Toshiba HD-A35
Remote: Logitech Harmony 890 Pro
2 Channel Setup
AVR: Pioneer VSA-910
Speakers: Klipsch KG4 (from 1985) -
http://www.jr.com/JRProductPage.process?Product=4213841
not that open boxes are available but just letting u know what they go for..Home Theater
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
Save up for the BD-50.
Im waiting for the 50.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
