Panasonic blu-ray
dholmes
dholmes Posts: 1,136
edited January 2008 in Electronics
The Pansonic blu-ray player, I think its the 10a model the one with 7.1 analog output is still available for around 450.00 is it worth it? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
  • steveinaz
    steveinaz Posts: 19,547
    edited January 2008
    I'd go for the BD30 at around that same price.
    billbillw Posts: 8,370
    edited January 2008
    Really depends if have an HDMI 1.3a receiver and want to bitstream the lossless codecs (Dolby TrueHD or DTS-MA) or if you want to send multichannel analog to your receiver. If you have a 1.3a receiver, then the BD30 is better because it can bitstream all of the formats and its a 1.1 profile player.
    If you want to send analog multichannel out, then the bd10 is probably better because it can internally decode DTS-HD/TrueHD and has 7.1 analog outputs.
  • dephinistr8
    dephinistr8 Posts: 61
    edited January 2008
    Heck for the price, might as well get the ps/3.
    Pros: already has HDMI 1.3, can internally decode audio or play them at bitstream
    Cons: Bluetooth only remote :(
    The Home Theater Setup:
    Fronts: Polk RTi6
    Center: Polk CSi5
    Surrounds: Polk FXi3
    Rears: Polk FXi3
    Sub: Polk PSW125
    AVR: Denon 3808CI
    TV: Mitsubishi 65" Diamond DLP (WD-65833)
    Game Console: Xbox360
    Game Console/Blu-Ray: PS3
    Satellite: DirecTV HD-DVR (HR21)
    HD-DVD: Toshiba HD-A35
    Remote: Logitech Harmony 890 Pro
    2 Channel Setup
    AVR: Pioneer VSA-910
    Speakers: Klipsch KG4 (from 1985)
  • margate21
    margate21 Posts: 105
    edited January 2008
    http://www.jr.com/JRProductPage.process?Product=4213841
    not that open boxes are available but just letting u know what they go for..
    lsi 15's, lsi c, lsi f/x
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • Dave38
    Dave38 Posts: 101
    edited January 2008
    Save up for the BD-50.
  • hockeyboy
    hockeyboy Posts: 1,428
    edited January 2008
    Im waiting for the 50.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
