Recommendations for receiver upgrade??
askinquestions
I have a yamaha htr-5760 right now. Goes along with lsi25's,lsic, a few polk satelites soon to be lsifx, and a sunfire amp to go along for the push. What I need to know or do, is see if a differant receiver would compliment the systems sound better. Mostly used for HT, and if you think a different receiver would be more beneficial, I wouldn't mind picking up a used one on ebay or something, as I don't really have to have new, which would allow for some quality at a discount. It just feels like the lsi's are maybe missing something. Thanks for any input........
Post edited by askinquestions on
Before looking to dump your gear,make sure it is set up right,and you play with placement a bit.For me,the yammie doesn't mesh well but thats just me.If you have a 5 or 7 channel amp doing the push,why use a receiver? Go seperate pre/pro,you'll be happier in the long run....and short run for that matter.HT SYSTEM-
lsi 9's -
What is your budget?
You could always go with a Sunfire pre/pro to match the amp, or other pre/pros like Rotel, B&K, Adcom, etc. If at all possible the next step after your amp purchase would be a good pre/pro, not another receiver.
Also, make sure to give the LSi speakers some time to break in. They'll open and sweeten up after 100-200hrs. -
I just checked out ebay, but I guess it would be best to try and narrow down by make and model. I just saw a sunfire III, if this is what your talking about.
askinquestions wrote: »I just checked out ebay, but I guess it would be best to try and narrow down by make and model. I just saw a sunfire III, if this is what your talking about.
Exactly, or a IV if you can swing it or find a deal on one.... -
I stalked Audiogon for quite some time until I got my Sunfire III prepro. It was well worth the wait. Here is one right here.
http://buy.audiogon.com/cgia/cls.pl?homeproc&1203059479
And here is a IV: http://buy.audiogon.com/cgia/cls.pl?homeproc&1204003108askinquestions wrote: »I just checked out ebay, but I guess it would be best to try and narrow down by make and model. I just saw a sunfire III, if this is what your talking about.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Notice the dudes name on the IV .....jesuscookies......HT SYSTEM-
lsi 9's -
There is some nice stuff on e-bay right now. I saw 2 outlaw 990's and also some rotel AVR's.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
That guy is on the Carver Forum, doesn't seem shifty on there...Just my $.02 -
LOL! I didn't even notice his name. He's got 2 clean transactions on Audiogon.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Bill Ayotte wrote: »Exactly, or a IV if you can swing it or find a deal on one....
What's the difference between this and a receiver... Seem to have the same functions...
I also think I might change my name to jesusquestions. -
There is no internal amp in a pre/pro like there is in a receiver. Since you already have a nice Sunfire amp, you may as well not pay for the amp side, you'll never use it...Unless you want to buy a Sunfire Ultimate Receiver II, and sell your amp (The Ultimate Receiver II has a internal 200X5 and all the functions of the TGIII if I remember correctly)....It's all about space and what you want to spend man, it sounds like you've got the room, so pick up the pre/pro and call it a day.
Anthony likes his Sunfire Receiver, you could sell the amp and just get the Sunfire receiver for a HT set-up. Your powered subs are already taking a big load off your system.
RT1 -
I love my Onkyo 7.1 receiver, lots of good clean power. Have always been a Kenwood man, but times change.
Bill Ayotte wrote: »There is no internal amp in a pre/pro like there is in a receiver. Since you already have a nice Sunfire amp, you may as well not pay for the amp side, you'll never use it...Unless you want to buy a Sunfire Ultimate Receiver II, and sell your amp (The Ultimate Receiver II has a internal 200X5 and all the functions of the TGIII if I remember correctly)....It's all about space and what you want to spend man, it sounds like you've got the room, so pick up the pre/pro and call it a day.
So why do they cost as much if not more than a good reciever??? Is it just better built??? If there are better components, I'm all for it. Like I said at the top, it just seemed as if the lsi's are looking for something, and maybe my current yammi is maybe a little behind in times.
