RTA 11T Broken Binding Post
Sax
Sax Posts: 70
edited January 2008 in Vintage Speakers
I have attached a picture of it, basically it must have been cracked or something, not sure, but I was changing cables the other day and it just broke in my hand...
Anybody have a spare binding post I could buy / know where to get one / or do I have to replace the whole pair?
I have already called polkaudio and they no longer carry the crossovers for this speaker, since the crossover in physically attached to the whole binding cup, I figured it was the whole unit, or if I call and specifically ask for a new binding cup would they still have that?
Any ideas / suggestions are welcome! Thanks.
Monitor 5b
RTA 11T
Rega Planar 2 (1970's)
Adcom GFA-545II
Post edited by Sax on
    F1nut Posts: 52,244
    edited January 2008
    You can replace just one. PM me your address info and I'll send you an original black one.
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2008
    Jesse beat me to it. I have a slew of them laying around after upgrading the SRS binding posts.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Sax
    Sax Posts: 70
    edited January 2008
    F1nut - PM sent
    This replacement part will of course fix my immediate problem, however after reading the forums a bit I see people have mentioned how they have upgraded both their crossovers and their binding posts and such...well when I had mine open I see there's really no easy way to do it per se, not a lot of room to work with, and I'm very inexperienced with soldering - i wouldn't want to compromise the sound quality with a botched soldering job.
    Does anyone out here have/make/offer to sale pre-modified terminal cups with upgraded crossovers? Or perhaps can recommend a shop to send mine to? Just a thought. :)
    Thanks again guys, never expected someone just having the spare part lying around but it makes sense
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
  • Marty913
    Marty913 Posts: 760
    edited January 2008
    Sax wrote: »
    F1nut - PM sent
    It's not that tough and doesn't really need soldering. You probably should invest in a $10 glue gun. You should be able to pick up a banana jack pair at any electronics store in OP. Maybe even Microcenter but certainly at Audioport at 96th & Metcalf, or you could order a pair for $5 - $8 at www.partsexpress.com.
    If your still leery of tackling it, there used to be a small electronic repair place (Daves's or Dan's, I think) at about 81st & Metcalf (East side of street) that will do it for you. You might also ask him if he will "upgrade" your crossovers if you supply the parts.
    Here's a couple of pictures to help. The hardest part is peeling off the old dried glue.The "backside" view is before mine were re-sealed with hot glue. Mine are from a SDA2, yours may be different. Still, sticking in the one from F1nut should be relatively simple.
    Go Jayhawks.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
    F1nut Posts: 52,244
    edited January 2008
    Your binding post is on it's way.
  • Sax
    Sax Posts: 70
    edited January 2008
    sweet! thanks
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
